Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Mounting Help!
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Ok, well i came to just another problem with my motor! My Mounting with the U Bolts did not hold ...
Old 03-07-2009, 12:21 PM
Default Mounting Help!
Ok, well i came to just another problem with my motor! My Mounting with the U Bolts did not hold the engine right, so i just decided to Drill thru my frame..i did that alright. Now that the engine is sitting straight down my tube, I run into the problem where my drive chain is touching my tire while resting on my Back tire Sprocket! Ive done everything, Ive added Washers to the engine, Ive pulled the engine to the left as much as i could, but it still wouldnt be straight with the sprocket. Im not sure the back Sprocket can move because theres a wedge on the outside, meaning if the sprocket moves a bit out, it will slide off. When i had the U bolt on i had the motor leaning about 1 inch to its side, but the motor was unstable that it would shake on a 30 min. ride
Can you guys give me some advanced techniques that might help (including welding techniques).
Old 03-07-2009, 12:27 PM
Default Re: Mounting Help!
Do you have pics? Is it a "normal" bike? is the tire just too fat? I had that problem when I put on a nice big fat mountain bike tire. The rubber got worn away in a month until I could see the belts.Is your sprocket the "dished" one or is it flat? The dished ones can be turned to get the teeth outwards.
Old 03-07-2009, 12:34 PM
ok i have a 7 speed Greenline beach cruiser bike, not sure how big the tire is but its filled to 40psi. My sprocket is just a flat 9 hole sprocket..the teeth seems normally equal all around...i have one big rubber circle on the outside of the spokes, one on the inside of the spokes.
Ive gotten to the point where im gonna hire someone to weld me some arms that will lean it out a bit. I just dont understand why they dont inform about this problem in any of the instructions.
Old 03-07-2009, 12:49 PM
Your just frustrated right now, there are thousands of us that don't seem to have your problem. I will search for a pic of your bike so that I can see the frame and hopefully, someone else will pipe in with thoughts. Just hang in there, these things always get solved.
Old 03-07-2009, 12:57 PM
I guess this is your bike. Having never worked on a cruiser style bike , I can't help you much but the frame seems normal.
I wish you luck and please don't give up, someone will help you.
Old 03-07-2009, 01:21 PM
thank you Toytime for the picture, Since i am at work i am not able to upload a picture of my bike, but that is the bike i have excluding all the flames. I AM frustrated, mostly because i cut half of my fender thinking it would solve the problem, but i dont care about that as long as i get a mounting technique that works.
If anyone has any suggestions with this kind of bike, let me know! thanks!
Old 03-07-2009, 01:40 PM
Here's a pic of a "dished" sprocket. It can be flipped around to bring the chain in closer or farther away. Do you think this would be enough to get that chain away from the tire?
Old 03-07-2009, 03:39 PM
MB-Monkey's Avatar
you acn also put some washers behind the sprocket before the first part of the rag joint to move the sprocket out a little
Ride it like you stole it!
Schwinn Jaguar 26" Beach Cruiser
49cc Dax
Jaguar Install Kit Manic Mechanic
Sick Bike Parts Head Gasket, Plug Wire, NGK Spark Plug
Thanks to Hiker472 for the Avatar.
HT Assembly Process
http://www.youtube.com/watch?v=U6ZfkS20oYI
HT motor testing
http://www.youtube.com/watch?v=p8Ycvad7NN4
The Amazing Wuggie
http://www.youtube.com/watch?v=hYznGdTfiR4
http://motorbicycling.com/f3/install...html#post77935
  #9 (permalink)
Old 03-12-2009, 10:12 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
It's ok if the chain rubs the tire a little.
  #10 (permalink)
Old 06-16-2009, 05:06 PM
tarstar's Avatar
i have the same issue i cannot fit it in place i have pictures available but just dont know how to pos tthem anyone who has a email i can send you them
N8TIVE
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f6/mounting-help-6565.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 03-07-2009 03:45 PM
