Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Motorcycle gas tank. Mounting?
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. I just bought an old motorcycle gas tank (freshly lined) I was wondering if anyone had any experience mounting one ...
Old 09-22-2009, 01:51 PM
Default Motorcycle gas tank. Mounting?
I was wondering if anyone had any experience mounting one to a Motor Bicycle
Motorcycle gas tank. Mounting?-dsc00333.jpg  Motorcycle gas tank. Mounting?-dsc00336.jpg  Motorcycle gas tank. Mounting?-dsc00337.jpg  Motorcycle gas tank. Mounting?-dsc00334.jpg
26" Schwinn Riverside (US Army Paint)
68.5cc Slant Head Engine (Powerking!)
SBP Expansion Chamber (Wrapped)
Stock 44t Sprocket
Considering investing in a shift kit
Old 09-23-2009, 08:33 AM
azbill's Avatar
Default Re: Motorcycle gas tank. Mounting?
I have mounted a 3.3 gal tank on a chopper (nirve deviate)
gallery384
most mount differently (frame specific),,,a pic would help us help you
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 09-30-2009, 09:50 AM
Just as an update,
I have tried many forms of manual mounting (clamps and such) all to no avail
I tried JB weld which just snapped right off (actually very surprised. bare metal and everything)
I even tried a form of synthetic clay
So far nothing has been able to hold up to the vibration
Stock 44t Sprocket
Old 09-30-2009, 11:18 AM
I've read else where that Double Stick Foam Tape is a good material to use for this type of installation. You might want to reduce the size of the tunnel using wood or plastic blocks attached with the same Double Stick These blocks could also be used to adjust the level/angle of the tank on your frame Here is a link to the type of tape I'm talking about. McMaster-Carr Click over to the second page and you will find the 3M Brand Very High Bond Tapes this is what you want.
ocscully
Old 09-30-2009, 11:31 AM
BarelyAWake's Avatar
hmm... haven't had to deal w/this yet - but other than burning/scarring the new liner you have (easy to patch w/new) I would seriously recommend having a few mount tabs at least brazed (preferably welded) on the underside of the tank.
It'd be cheap enough as it'd only take a minute if you had the tabs all made up and the tank prepped (sanded clean where the tabs go). I would never trust double sided tape for that job, particularly as gasoline is such a fine solvent for that type adhesive. Sooner or later you'd spill fuel and run the risk of loosing yer tank at speed o_O
The double sided foam tape is much better used in conjunction with proper mounts - to reduce movement/noise, that might be what you read about. I wouldn't just tape ANYTHING to my bike and expect it to stay lol and the fuel tank is somewhat important
Old 10-07-2009, 08:20 PM
I'd use the same stuff I used for my bottom motor mount...black RTV gasket sealer. It is rubber-like and solid. That stuff ain't goin nowhere.
Old 10-07-2009, 09:05 PM
Check out this link for a nice cheap fuel pump $15. It is 12 volts though. Anyone know of a tank the shape of the old ammunition boxes they used in the military? Be perfect for the rear mount.
Electric Fuel Pump | Bujold Hobbies Inc. (Hobby Zone)
Old 10-07-2009, 10:00 PM
Kevlarr's Avatar
Get some foam pipe insulation to go around the top tube of your frame. I'd make a frame clamp that uses the pins already in the tunnel. Take a couple of pieces of flat bar, find some grommets that just fit over the pegs on the tank, drill the flat bar to fit the grommets, bend the flat bar into kind of a goblet with a ball stem shape so the ball section clamps around your frame and the goblet section has the grommets for your tank pegs.
Nothing to scale but here's a quick model I made
Motorcycle gas tank. Mounting?-tank-bracket1.jpg  Motorcycle gas tank. Mounting?-tank-bracket2.jpg  Motorcycle gas tank. Mounting?-tank-bracket3.jpg
  #9 (permalink)
Old 10-19-2009, 10:26 PM
Kev, that's so simplistic it's brilliant!
Steve
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f6/motorcycle-gas-tank-mounting-11437.html
Posted By For Type Date
Motorcycle gas tank. Mounting? - Motorized Bicycle Engine Kit Forum | Bicycling Leisure Knowledge This thread Pingback 09-23-2009 03:17 PM
