Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
The Most Stable Medium!
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Hello, I wanted to share my knowledge here in the engine mount section. I've been through it all, stripped ...
Old 10-03-2009, 07:38 AM
ADDICTED MOTORBICYCLES's Avatar
Default The Most Stable Medium!
Hello, I wanted to share my knowledge here in the engine mount section. I've been through it all, stripped studs, snapped brackets, and oh, the ever torturous engine tilt. If you have this problem, when the engine is tilting to the left because the mounts keep slipping, then I have your solution!!! This will not allow your engine to tilt anymore, and also doubles as a vibration reducer! If you have Nylock nuts on your engine mounts, then once you use this stuff, you'll have no more worries. So here it is. It's non-slip mat, I got it at a dollar store for a buck. It comes in a long roll, so for a buck you can mount thirty or more engines before you need to buy another roll! Here is a couple pictures, and a link to a video where you can see it also. I hope this helps you all, good luck, and ride safe!
Video: VID2000166.flv video by ADDICTED-BICYCLE-CUSTOMS - Photobucket
most-stable-medium-img00657.jpg  most-stable-medium-img00658.jpg  most-stable-medium-img00659.jpg
Old 10-06-2009, 02:15 PM
Default Re: The Most Stable Medium!
very nice idea, thanks
Old 10-07-2009, 01:41 AM
Great find there AD! That stuff surely does work for alot of things
Old 10-07-2009, 01:32 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I really advise people not to use any kind of vibration dampers between the engine & frame; because anything that is soft enough to dampen the vibrations will eventually wear down over time & cause problems.
Old 10-08-2009, 08:09 AM
I agree, everything seems to fail. However, so far, I haven't had to make a single adjustment to my engine mounts. No loose nuts, no change in vibration, no slippage to the left or right. My chain tension has remained constant, and other than the screw holding the small sprocket on the inside right of the engine coming loose twice, I've had absolutly no problems. It's a record for me, I usually break down once every other day! It's been two weeks or something like that since the last breakdown. So far, the non-slip mat is the way to go, it's lasted longer than anything else I've tried. Perhaps it may fail eventually, but it doesn't seem to be loosing anything so far.
Old 10-08-2009, 08:59 PM
markeatmark's Avatar
that's a good idea. You sais it's from the dollar store. how much dose it cost? LOL just kidding that is a good idea. on the bike i have now i used leather from an old tool pouch. I will let you know how it holds up over time
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f6/most-stable-medium-11725.html
Posted By For Type Date
The Most Stable Medium! - Motorized Bicycle Engine Kit Forum | Bicycling Leisure Knowledge This thread Pingback 10-04-2009 03:18 PM
