Modify the mounts or the frame
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. can anyone send me some pictures or links to pictures to help me decide how to mount another 80 cc ...
Old 04-01-2008, 07:25 AM
Motorized Bicycle Builder
Default Modify the mounts or the frame
can anyone send me some pictures or links to pictures to help me decide how to mount another 80 cc chinese to this frame.
Im pretty sure the engine wont bolt right uo to this frame
Old 04-01-2008, 08:12 AM
Ilikeabikea's Avatar
Default Re: Modify the mounts or the frame
On my Schwinn I drilled a hole through the frame and put a spacer and a flat plate on the spacer. The flat plate bolts to the front engine mount. I don't think I have a picture of it on this computer. Lots of different ways. Cruiser might have some pics of the way he did his on the forum. He'll chime in after while...................
http://bdconner.com
Old 04-01-2008, 08:34 AM
deacon's Avatar
I would still go with the muffler clamp if I was you. I don't have a picture either but there is one around somewhere. The clamp is a u bolt on one side that would wrap around the frame, then a channel bar on the other side that is u shaped on one side to grip the frame then flat to bolt up to the engine mount. You would have to drill some holes and buy some replacement bolts for the studs in the engine, but it would save your frame. It would also be infinitely more adjustable than a hole in the frame as well.
I have never used one but if I had an over sized frame it's what I would do.
visit my blog if you dare ... Riding in the hood, The deacons facts and fiction.... http://chinesekitmotorbike.blogspot.com/
Old 04-01-2008, 11:21 AM
spad4me's Avatar
I carefully contoured my front motor mount to match the frame , and pretty much did what deacon did.
I also use Goop to glue the motormount to the frame.
All About Goop Adhesive on the Natural Handyman home repair and do it yourself website
The goop site uses an annoying flash movie.
Old 04-01-2008, 06:47 PM
I dont think the tubes are oversize they just dont make the perfect v that you need for the engine to nestle down into.
The seat tube will be ok but the other tube sorta goes straight out then curves up.
I guess I gotta get the engine bolted to the seat tube then go from there.
I just thought some one might have some pictures to give me some Ideas.
Ted
Old 04-01-2008, 07:38 PM
deacon's Avatar
I think the way to do it is to loosely hook the seat tube end, then move the front of the engine around till you get the best seat for it. That will require that you move the rear (seat tube) up and down as well. I use a little auto heater hose to fill the gaps. I have moved my motor from one bike to another so they had to be reset both times.
Old 04-01-2008, 08:49 PM
Here's how I did mine. It's not that great of a picture but it's all I have. If this won't work let me know and I'll go out and take a pic of just the front mount. But that may take me a day or two. Hope this helps.............
http://bdconner.com
Old 04-01-2008, 09:34 PM
Another question pertaining to mounting an engine, how much of a foreward incline will an engine tolerate before performance is affected?
Ted
  #9 (permalink)
Old 04-01-2008, 09:47 PM
Angle of engine will make no difference. Angle of carb is what needs to be somewhat level.....................
http://bdconner.com
  #10 (permalink)
Old 04-02-2008, 08:32 AM
I dug around on my old laptop puter last night and found this pic. Hope this helps..........................
http://bdconner.com
Similar Threads
Just bought 4 stroke Chinese bicycle engine frame mounting kit geeksquid Bicycle Engine Kits 42 05-22-2008 10:02 AM
Frame question sorta. deacon Mounting Techniques 25 05-17-2008 05:01 PM
Frame Damage? SeattleMike Motorized Bicycle General Discussion 7 03-26-2008 06:26 AM
Old Frame RedB66 Motorized Bicycle General Discussion 9 01-25-2008 06:21 AM
preserving your motorized bicycle frame CRUISER Mounting Techniques 10 01-17-2008 01:49 PM
