Modify the mounts or the frame
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. you know I have a perfectly good bolt cutter I have no idea why I didn't think of that. ...
  #11 (permalink)
Old 04-02-2008, 08:53 AM
deacon's Avatar
Default Re: Modify the mounts or the frame
you know I have a perfectly good bolt cutter I have no idea why I didn't think of that. You don't need to replace the studs with bolts just run them down tight and cut off the surplus.
Sometimes it just takes a while to change your mind set.
visit my blog if you dare http://chinesekitmotorbike.blogspot.com/
Full novel on the blog in serial form.
  #12 (permalink)
Old 04-02-2008, 10:05 AM
VincenT's Avatar
Motorized Bicycle Apprentice
another option to the muffler clamp would be a tower standoff. I used them on both my builds. They mount to the engine and attaches via stainless steel hoseclamp. Haven't had any issues with them so far. I used heat shrink to the bottom, so not to scratch the frame. The standoff is .25", so no worries of flex or warpage.
  #13 (permalink)
Old 04-02-2008, 10:11 AM
deacon's Avatar
Looks good to me.
  #14 (permalink)
Old 04-03-2008, 11:47 AM
CRUISER's Avatar
ADMINISTRATOR
looks real good. the motor mounts on these bicycle motors almost always have to be modified to work
  #15 (permalink)
Old 04-08-2008, 09:09 PM
Where can I find a tower standoff I have yet to find anyone who even knows what they are?? I have tried Home Depot Radio Shack Circut City? where can I get one?
  #16 (permalink)
Old 04-09-2008, 07:13 AM
VincenT's Avatar
Here's a link to an ebay seller...
10 Andrew Stainless Tower Standoff Kits 30848-4 - eBay (item 270179383160 end time Apr-19-08 23:24:56 PDT)
a couple of hints when using a standoff... you will have to grind a little off the inside edges to clear the bolts from the engine. Trim the engine bolts about .75" . For the stainless steel clamp, use .5 x 4" heat shrink, it will cover the clamp and protect the frame a little. If you crank too tight on the clamp it will strip.
Similar Threads
Just bought 4 stroke Chinese bicycle engine frame mounting kit geeksquid Bicycle Engine Kits 42 05-22-2008 10:02 AM
Frame question sorta. deacon Mounting Techniques 25 05-17-2008 05:01 PM
Frame Damage? SeattleMike Motorized Bicycle General Discussion 7 03-26-2008 06:26 AM
Old Frame RedB66 Motorized Bicycle General Discussion 9 01-25-2008 06:21 AM
preserving your motorized bicycle frame CRUISER Mounting Techniques 10 01-17-2008 01:49 PM
