Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Look at this cool homemade bike
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. Take a look at this homemade bike from Youtube. It's a very cool, smart setup, different than all the ...
Old 07-19-2008, 12:14 AM
Motorized Bicycle Builder
Default Look at this cool homemade bike
Take a look at this homemade bike from Youtube. It's a very cool, smart setup, different than all the others. It appears that he's using a standard gokart/mini bike clutch and chain and somehow attached a kart/minibike sprocket to the crank. And I'm assuming he still has use of the bike's gears! And it's very fast, too. He's using a Honda clone engine and the only thing I'd change is to use a Robin Subaru engine instead, that is if I didn't already have a Briggs or some other engine already. Not the tiny Robin Subarus, but the larger ones that look much like the engine he's using. Anyone have any good ideas on how to attach and center the sprocket to the crank? I'd suggest doing this before making the motor mounts so the engine can be properly lined up with the sprocket. I've sent this guy a message, but most don't answer, so I'm throwing it out there.
Old 07-19-2008, 12:21 AM
Default Re: Look at this cool homemade bike
Here's a Robin 6 hp. It even has a charging coil.
Old 07-19-2008, 12:47 AM
hi; do you think there is a cop on this planet that would beileve---its a 48cc sir
Old 07-19-2008, 12:51 AM
I've actually known a few that would believe it.
Old 07-19-2008, 01:35 PM
UncleKudzu's Avatar
no pedals, though that'd be a cool set-up if it was still possible to freewheel and pedal.
as for a homemade motorcycle, though, that looks like a smart solution.
Old 07-19-2008, 02:07 PM
eDJ's Avatar
eDJ eDJ is offline
Can you say Riquimbili !
I think that's a very clever and simple set up. Most of the effort would be in finding the right bicycle to start with. I'd hunt for one with the dismountable
pedal levers that mount to the short crank using those tapered pins with a flat side to them. If the left pedal lever could be cut so to form a mount the pully could be welded/bolted to......then the pully assembly could be reattached with that pin and secured with a nylon retainer nut. It may take a socket with extension/swivel to secure the nut but I'm sure it could be easily done.
The welding of a plate support for the motor between the front diagonal frame tube and the seat post would not be difficult at all, not to mention the foot pegs. (but get a skilled welder for this who knows his trade and explain what you're doing so he can reinforce the engine platform)
Selecting a motor with a centrifigual clutch and adjustable carb would be the next chore. With fall coming alot of yard equipment will be showing up in flea markets at the end of season. Often those who mow commercially sell their
stuff off at the end of the season so they can buy new at the beginniing of the next season. You may find a piece of machinery that's worn out/damaged with a still usable motor for a project like this. (if the project works out to your satisfaction.....you can always overhaul the engine during the winter)
This would be an interesting project with a 5 speed rear shift especially riding around hills. If gear #3 was your default starting out gear you'd have two over drives and the ability to really run the flat stretches of highway.
The only thing I would do to the bike in that picture is BUILD A PULLY GUARD
and enclose that primary belt drive. It wouldn't be at all hard to do. A piece under the motor mounting that sticks out just past the pully's would have a flat piece of metal with several holes welded to that. Then a pear shaped piece of sheet metal could be cut the belt profile and around that some aluminum angle 1"x1" angle could be attached to it for a lip. The guard would attach at the center between the pully's with bolts etc to support it making the thing safer to ride if you were wearing pants. But all of the primary drive needs to be covered as one of those two pullies will be turning in a direction that would pinch or pull you into it.
I could see an emerging market for these things with younger guys who want something that nobody else has. (and they can proudly proclaim...."I Built It")
They may have to license and insure it as a motorcycle but it would be a fuel efficient bike where parts wouldn't be ultra expensive or unavailable. It's no wonder that when I was a kid I'd see little old retired men on motorized bikes.
Thanks for posting that Starrunner......I've been considering a Riquimbili project for my next bike and I have just the bike on hand that would lend itself to doing this. Just need to find a motor with clutch and some control cables etc. I like everything about that. The primary belt cover would really set it off. The seat looks like it's off a stationary Gym bike too.....extra comfy.
Old 07-19-2008, 02:19 PM
UncleKudzu's Avatar
Originally Posted by eDJ View Post
... the dismountable
pedal levers that mount to the short crank using those tapered pins with a flat side to them. If the left pedal lever could be cut so to form a mount the pully could be welded/bolted to......then the pully assembly could be reattached with that pin and secured with a nylon retainer nut.easily done.
ahh... good insight, eDJ; i'll bet that's how it was done
go for it, Senor Riquimbili!
Old 07-21-2008, 03:05 PM
deacon's Avatar
think chainsaw
Advertisers
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
