Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Just how wide is a Wide Pedal Crank?
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. The title says it all. I'm looking at mounting a 4-stroke with a centrifugal clutch in the frame. ...
Old 07-11-2008, 05:10 PM
cachehiker's Avatar
Default Just how wide is a Wide Pedal Crank?
I'm looking at mounting a 4-stroke with a centrifugal clutch in the frame. I assume the wide pedal cranks are provided to ensure the crankarms miss the sides of the engine. Anyway, has anybody actually measured the Q-factor of these cranks?
I'm looking to motorize a ten year old GT with a standard UN-72 square taper bottom bracket. It's a triple crank that would be converted to a single ring in the front. I already have a much wider bottom bracket that I could use to put the crank arms out another half inch or more but I need to know how wide is wide enough.
Old 07-13-2008, 09:28 AM
Default Re: Just how wide is a Wide Pedal Crank?
I guess it depends on the design and engine placement. I run a wide bb, 127mm, but this doesnt clear the motor. I placed the motor forward and higher so the cranks clear. Most frames dont have room for the motor in this space so you may need an x/large frame or custom made.
Old 07-13-2008, 10:55 PM
cachehiker's Avatar
If 127mm doesn't clear the motor for you, I'm pretty sure I won't make it either. It looks like I can fit a 48cc 2-stroke in there if I can find a clutch actuating mechanism that I like. I don't want two levers on the left side and since I'm a cyclist first, I don't want to get used to braking solely from the right.
Old 07-14-2008, 01:22 PM
The Optional Wide 3-piece crankset offered from GRUBEE and other vendors are designed to clear the Honda GXH50/Clone motor and its attendent gearbox. This set-up is 9.5 inches wide. The wide crankset is designed to clear this with what ever square tapered BB your bike has for its existing crank set. The wide crankset is also a single 44t sprocket. Just changing to a longer spindle isn't even close and would cause chain line problems for the pedal side as well if you could find a spindle long enough.
ocscully
Just
Old 07-14-2008, 01:58 PM
My Honda GXH50 plus a GruBee gear box is 232mm (9 1/8") at its widest point. Below the bulge for the bearings it is only 222mm (8.75")
My three piece peddle set clears 229mm (9")
The one piece that I could not use is 225mm (8.75")
I just installed the wide cranks yesterday on the 38mm (1.5”) factory lower bracket. The one piece crank requires a 51mm (2”) lower bracket to fit through and use the bearings that come with it.
The attachment is a picture of the new wide cranks. Jim
Easy does it, but do it!
Old 07-23-2008, 08:24 PM
MotorbikeMike's Avatar
Dealer
Cachehiker, contact me if you like, I have Rotary clutch handles (match the old-style throttle)
Mike
www.ezmotorbike.com www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
Old 10-19-2008, 10:09 PM
Dan's Avatar
Dan Dan is offline
Hi jimraysr. Where did you get your cranks?
Originally Posted by NEAT TIMES View Post
looking In The Sky, May See Dan Flying By!! Ha Ha Ron
I want 2 ride my bicycle
Old 10-20-2008, 02:31 AM
Spooky Tooth. Think they were $20. Just the two cranks that fit on the square spindle of the lower bracker. The type that have internal threads for a removal tool and are retained by a bolt into the spindle. Good Luck.
Trying to find these parts often seems to be the most time consuming part. Guess I am going to have to buy a minil beer keg and make my own round tank to go behind the seat?
Jim
  #9 (permalink)
Old 10-20-2008, 06:05 AM
Dan's Avatar
Dan Dan is offline
Thanks Jim.
Your right about the time used for just finding all the stuff that will play nice together. Can be maddening.
  #10 (permalink)
Old 10-20-2009, 12:41 PM
Jim
Hi Jim, Nice pedal cranks you have.
I don't see these on Spooky Tooth's online parts list. (only the one piece crank set) Did you have to call Spooky's for them?
