Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
JB Weld on mounts
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Hello, I have my 70cc motor mounted on a mountain bike. The bottom frame was too thick to use the ...
Old 06-19-2008, 02:12 PM
Motorized Bicycle Apprentice
Question JB Weld on mounts
Hello,
I have my 70cc motor mounted on a mountain bike. The bottom frame was too thick to use the stock motor mount, I had to use the long bolt and plate that came with Dax kit. It worked good, but I ended up losing one of the bolts that attach the plate to the original mount point (I replaced original long studs with bolts) even with lock tite after about an hour long ride.
My questions is, has anybody tried JB Weld to secure their mounts. I was thinking of just cold welding the plate to the original mount point.
Thanks in advance,
Roman
Old 06-19-2008, 02:26 PM
Pablo's Avatar
Default Re: JB Weld on mounts
If I am hearing you correctly - it does not sound like a good idea.
Old 06-19-2008, 02:47 PM
Maybe this will help. Sorry i am at work at the moment, all I could do in a short amount of time
Just to fuse the plate to the bottom mount, and maybe put a bead on each bolt. (I heard you can use soldering gun to melt them off if needed later)
Old 06-19-2008, 02:51 PM
Ghost0's Avatar
I would just use blue locktite.
Old 06-19-2008, 02:53 PM
Pablo's Avatar
OH I gotcha - there must be a fundamental reason why Loctite didn't work. What type of Loctite? How old is it?
I don't see bonding those areas helping all that much but on the heads may help a bit.
filestyle1's Avatar
I wouldnt , just because , too many what ifs
I'll keep rollin "FileStyle"
"I'am just a penny short of being a millionaire"
Old 06-19-2008, 03:08 PM
misteright1_99's Avatar
I agree with Ghost. Loctite, and maybe some good lock washers........
Old 06-19-2008, 04:03 PM
I used locktite blue (med strength).
Thanks for your responses. I guess I will try again with locktite. And maybe use a better lock washer (was using regular spring lock washers).
Cheers
  #9 (permalink)
Old 06-19-2008, 04:24 PM
Default I have done at least 300 builds and ....
and thousands and thousands of miles. I have never ever had to use loctight. Ever.. If you need to use loc tight, you are doing something wrong. Loc Tight will void any warranty. Loc tight will ruin your engine. Never use loc tight on these little motors. Loc tight has its place in the world. But it has no place anywhere on these little motors. Enjoy the ride...
visit www.thatsdax.com for more !!
  #10 (permalink)
Old 06-19-2008, 04:40 PM
I dont really see how locktite will "ruin your engine"... It may seize the bolt in place, but thats hardly a ruined engine.
A lot of people on this forum seem to use it.
Advertisers
