| | How tight should I tighten the sprocket bolts? Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. I'm installing my 80cc on my mountain bike now. How tight should I tighten the sprocket bolts? I have ...  | |
03-19-2008, 08:48 PM
|  | Senior Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Seattle, WA
| | How tight should I tighten the sprocket bolts? |
03-19-2008, 09:02 PM
| | Re: How tight should I tighten the sprocket bolts? I used 1/4" drive ratchet and tightened about as tight as I could with one hand. I didn't get brutal or anything just good normal tight. I started out with them just snug and went round and round tightening them trying to keep sprocket straight. Hope this helps.......................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............ http://bdconner.com |
03-19-2008, 09:54 PM
| | Re: How tight should I tighten the sprocket bolts? I should have read the instructions that came with my kit instead of looking at those picture instructions from zippycycles.com ! The photo of the sprocket shows both rubber washers on the inside of the spokes, rather than one on the inside and one on the outside like my instructions say. I have a feeling my instructions are right, what did you guys do? |
03-19-2008, 10:00 PM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: How tight should I tighten the sprocket bolts? yes one on inside and one on outside. here is a pictorial on installing the sprocket motorized bicycle 44 to 36 tooth sprocket swap the pictorial is about changing out site of you sprocket but great for initial installation also
03-19-2008, 10:20 PM
| | Re: How tight should I tighten the sprocket bolts? This forum is so great, you guys are really helpful and nice! Thanks |
03-19-2008, 10:28 PM
| | Re: How tight should I tighten the sprocket bolts? The instructions I saw recommended a rubber washer on inside and outside only for bikes with coaster breaks. I'm not sure why that would make a difference.
__________________  |
03-20-2008, 08:02 PM
| | Re: How tight should I tighten the sprocket bolts? Follow our instructions and you will be successful if you don't understand anything don't be afraid to ask. I use the fiber gasket on both sides to get a good grip on the spokes, keeps the sprocket off the spokes, provides space to aline the front and rear sprockets.
Norman
03-21-2008, 06:47 AM
| | Re: How tight should I tighten the sprocket bolts? One on the inside, one on the outside, it's the only way it will work and keep working.
03-24-2008, 07:38 PM
| | Re: How tight should I tighten the sprocket bolts? Listen to Joe.
Norman
03-24-2008, 08:12 PM
| | Re: How tight should I tighten the sprocket bolts? I agree its the only way that makes sense. Metal and metal will never grip like that wrap around fiber.
I tightened mine till I felt like the nut stopped moving, not till the puller handle bent. But you should check it now and then, as it will probably get loose after a while. Everything gets loose after a while | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | head bolts | ZOOMCAT | Motorized Bicycle General Discussion | 7 | 03-15-2008 10:17 PM | | Only eight bolts fit sprocket!! | TeddyB | Bicycle Engine Kits | 3 | 01-25-2008 10:43 PM | All times are GMT -5. The time now is 10:07 AM. |
