Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Help with ghetto mounted gas tank
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Mounted with zip ties to the seat. electrical tape it theres so it doesnt look as ghetto as it did ...
Old 06-25-2009, 10:53 PM
lowrider's Avatar
Default Help with ghetto mounted gas tank
Mounted with zip ties to the seat. electrical tape it theres so it doesnt look as ghetto as it did before.
I need a better mounting method please help.
any ideas are appreciated.
CPS3C
Worlds Largest Selection Of Custom Modified Gaming Consoles & Accessories.
http://www.customps3controllers.com
I do a lot of custom paint on these gaming consoles
So if anyone is interested in having their tanks, fenders,frames & any other parts painted
drop me a line.
Old 06-26-2009, 01:04 AM
Default Re: Help with ghetto mounted gas tank
wow how hard is that thing to fill have you thought about pipe clamps just paint them black should work or maybe even weld it on jb weld might hold also but i would say pipe clamps
if you dont see smoke your doin somthing wrong fly low beat the radar
04 shcwinn 80cc dax sbp camber cns carb boost bottle k&n filter 36 tooth 40mph (gps tested) havin fun and smokin scooters
Old 06-26-2009, 01:06 AM
lowrider's Avatar
no problem filling the cap is clear of the seat.
I thought about pipe clamps but if i mount it to the frame it will be to low
CPS3C
drop me a line.
Old 06-27-2009, 05:55 PM
Cabinfever1977's Avatar
get a roll of chimney strapping or muffler strapping
Old 06-30-2009, 11:43 AM
HoughMade's Avatar
Here is what I would do...but keep in mind, I go a little overboard.
Either use the strapping above or (and this would ne my preference) use thin strips of steel (2) that will reach around the tank. I would go with abou 3/4" to 1" wide at 22ga of maybe even 26 ga.
Get a "U" bolt at the hardware store- not a muffler clamp, too big. Get a "U" bolt that is just big enough to go around the seat post. Face the "U" bolt up, that is, with the close end down and the open end up. Below is a rough drawing of what I mean. Put the plate across the "U" bolt and tighten it down.
Get the 2 metal strips and bend them around the tank so that one lines up with one side of the bolt, and the other the other side. Then overlap each strip so that the ends cross over the bolt. Drill a hole through both ends, get a washer and nut, and bolt it down on each side.
Again, refer to the rough (very rough) drawing.
help-ghetto-mounted-gas-tank-100_1303.jpeg  help-ghetto-mounted-gas-tank-100_1304.jpeg
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 06-30-2009, 11:47 AM
lowrider's Avatar
nice very nice I plan on doing this or something similar to this. going to the hardware store today!!
CPS3C
drop me a line.
Old 07-05-2009, 02:01 AM
lowrider's Avatar
: Update :
CPS3C
drop me a line.
Old 07-05-2009, 02:04 AM
lowrider's Avatar
Originally Posted by lowrider View Post
: Update :
As you can see the leaky gascap has ruined my nice paint job
CPS3C
drop me a line.
