Frame question sorta.
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. LOL but it sounded so good rofl...
  #21 (permalink)
Old 01-18-2008, 07:00 PM
deacon's Avatar
Default Re: Frame question sorta.
  #22 (permalink)
Old 01-20-2008, 12:38 PM
Norman's Avatar
LORD VADER Moderator
Deacon
If you are going to change the front forks get a fork that has suspension you can get them on ebay for $20.00 or less if you do the bid or by it now as for inner changeability you are more than likely going to need to cut and weld on things. You might be biting off more than you can chew for right now get all the bugs out of the bike and get her well broken in before changing thing big time. You get it figured out later on what you want to do I know i live a long ways away but I'll weld up what you send for changes. Sound good to you?
Norman
  #23 (permalink)
Old 01-20-2008, 01:36 PM
deacon's Avatar
Im at the dance naked on the lawn phase again lol... Why did I ever get involved in this rofl.
visit my blog if you dare ... Riding in the hood, The deacons facts and fiction.... http://chinesekitmotorbike.blogspot.com/
  #24 (permalink)
Old 01-20-2008, 03:35 PM
Norman's Avatar
Bikeguy Joe
I'm guilty of using conduit on frames but not forks, love the fumes too when welding makes me want ot wear my magic helmet and I've yet to find my spear. Hey thats where it went into a frame..
  #25 (permalink)
Old 01-20-2008, 05:13 PM
deacon's Avatar
very cool.
  #26 (permalink)
Old 05-17-2008, 05:01 PM
Wink Re: Frame question sorta.
Loosen up the gooseneck bolt, tap it on top with a plastic hammer or use a thin board and a real hammer it will pop the clamping device inside the fork.
Stradle the front wheel and twist the bars back and forth pulling gently up.
If its dirty clean it up. DO NOT use ANYTHING with oil grease ect. Wire brush
old clean rag. Cresent wrench to remove big nut on top, then top race. BE CAREFUL. On some bikes the ball bearings ore LOOSE. If you loose any you HAVE to replace or find them. The bottom is the same. Use a good grease
clean the bearings,race and pack the top & bottom race and put the bearings back. Slide the 26' FRONT fork in and reassimble. A 24' don't have the room &
if you are using a fender no way. Hope this helps Saddletramp
Similar Threads
Old Frame RedB66 Motorized Bicycle General Discussion 9 01-25-2008 06:21 AM
cross engine question deacon Motorized Bicycle General Discussion 10 01-17-2008 12:41 PM
