Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
First Build Aluminum Frame, Mistake??
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. Hello Everyone, I think I made a big mistake by choosing a mountain bike with an aluminum frame for my ...
Old 02-11-2009, 09:05 PM
TyDow's Avatar
Default First Build Aluminum Frame, Mistake??
Hello Everyone,
I think I made a big mistake by choosing a mountain bike with an aluminum frame for my first build. I know I should not drill the frame to mount the engine but do you guys have any other major suggestions regarding aluminum frames? Just want to make this first build as easy as possible. I bought my kit from dax.
Thanks
Ty
Old 02-11-2009, 10:27 PM
FileStyle's Avatar
Default Re: First Build Aluminum Frame, Mistake??
so far , so good I have a aluminum GT Agreesor with 2300 miles on it. one hole in the frame. just dont drill through the frame to mount the motor. I used a custom adaptor plate for the front of the motor and then used a 5/16" u bolt to secure to the frame. I would have really preferred to use a good steel frame instead though! just to reduce possibility of stress,vibration cracks.
" We cannot live through a single day without making an impact on the world around us. And we all have free choice - what sort of difference do we want to make?" ~Jane Goodall~
Old 02-12-2009, 01:53 PM
wheelbender6's Avatar
You can use a muffler clamp to reach around those fat aluminum tubes. Many examples of that on this site.
If you have a bargain aluminum bike, inspect the welds often.
Aluminum frames from major brands (GT, Trek, Specialized, etc) should be more than adequate.
"Don't believe everything you read on the internet. That's how World War I got started" - PS3 commercial
Old 02-13-2009, 07:20 PM
Originally Posted by TyDow View Post
Hello Everyone,
Thanks
Ty
Ty Dow, I have an aluminum frame bike also. What I did to mount my engine turned out fairly simple, and I highly recommend it. First wrap a
piece of old inner tube once around the area of the frame where you plan to mount the engine. next, measure the diameter of the frame and tube at the front mount and the rear mount. Purchase two muffler clamps for the two frame mounts. Also buy a flat piece of 1/8 or 3/16"
thick aluminum. Cut the aluminum into two pieces, about 3-!/2" wide and about 2-1/2" tall. Drill two holes in each piece to allow the motor mount bolts to fit through. Then drill two more holes for the muffler
clamps to go through. This will allow you to mount the motor without
damaging the frame, plus help eliminate some vibration too. I hope
this make sense to you. It took me MANY hours of trial and error to
figure this out.
Old 02-14-2009, 06:29 PM
deacon's Avatar
minor bike philosopher
I just put my first hub motor on a thin alum frame road bike. I have about ten miles on it and I like it. It is much easier to roll in and out of the shop. I have a nasty little turn around a door that used to break my back with the steel bikes I built.
I had to do a couple of things to make it fit but no drilling.
Me and the Ebike
New Novel in progress blog...
Old 02-14-2009, 08:46 PM
fairracing31's Avatar
Here is a aluminum frame bike that USABikeMotor.com is building
They have a front motor mount that bolts to the existing bolt holes for the water bottle cage.
first-build-aluminum-frame-mistake-barribikeusa002.jpg  first-build-aluminum-frame-mistake-barribikeusa033.jpg  first-build-aluminum-frame-mistake-barribikeusa034.jpg  first-build-aluminum-frame-mistake-barribikeusa035.jpg
Old 02-15-2009, 02:23 PM
TyDow's Avatar
Nice idea! Kewl!
