A diffrent drummer
Discussion at Motorized Bicycle Engine Kit Forum in the Mounting Techniques forum. I found a 24" Schwinn mans bike & cut the tubes 2'' behind the seat post and made the ...
Old 05-19-2008, 06:33 PM
Smile A diffrent drummer
made the frame 25'' longer. Had to remove the top tubes & re-weld them. The
angle on the top tubes did not line up. I used new tube for all of it. It was not
easy but it went together well. Thanks to my welder friend Butch Mounted a steel plate drilled & mounted a HONDA 4.5 horse edger motor to it. Used an old clutch from a mini bike also the throttle. Still need a sprocket, and a chain guard I can make that. I used Bondo ( car body filler) to mold in the welds. It looks nice. May need a 26" rear wheel frame sits kinda low. The peddles clear the ground by 3". I don't think thats enough. Going to have to make the drive chains as they are not near long enough. I'm using the little white basket that came w/the bike for emptys
Old 05-19-2008, 06:41 PM
Bikeguy Joe's Avatar
Default Re: A diffrent drummer
Photos? Photos!
Old 05-19-2008, 07:35 PM
deacon's Avatar
I found that a crank set from a child's 20 gets the pedals up and down. In other words the pedal arms are shorter. Give you more clearance without hardly any work. Those kid's bikes are everywhere.
visit my blog if you dare http://chinesekitmotorbike.blogspot.com/
Full novel on the blog in serial form.
Old 05-19-2008, 07:49 PM
nogoodnic's Avatar
Pictures please. This bike sounds really cool can't wait to see it...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
