Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Won't start - no spark (possibly)
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. You can buy a new magcoil from that'sdax or possibly other sellers for under 20 dollars. Have you checked ...
  #11 (permalink)
Old 05-11-2008, 07:12 PM
Bikeguy Joe's Avatar
Default Re: Won't start - no spark (possibly)
You can buy a new magcoil from that'sdax or possibly other sellers for under 20 dollars. Have you checked with your seller for a replacement/warranty?
  #12 (permalink)
Old 05-11-2008, 08:17 PM
Why don't you ask the guy who sold the engine to give you another magnito?
  #13 (permalink)
Old 06-03-2008, 07:33 PM
Motorized Bicycle Apprentice
I think the magneto is fine - I found out that the blue wire lost connection and was kinda just hanging around near the magneto. I tried to solder it back to where I thought it went, but I am not getting spark still.
Can someone post up pictures of where the blue wire is soldered to the side of the magneto? I want to make sure I put it back in the right spot.
  #14 (permalink)
Old 06-03-2008, 08:18 PM
fairracing31's Avatar
I hope you can see it well, I do have one out of the motor but it is at work. Hopefully I can remember to bring it home tomorrow so you can see it better.
The Blue wire goes on the top of the winding, white wire to the bottom, and black is ground
  #15 (permalink)
Old 06-05-2008, 12:44 AM
AH THANK YOU!!!!!! i soldered it onto the outside of the magneto on the steel part rather than the copper part. Hopefully this will solve my issue! I'm so excited now!
  #16 (permalink)
Old 06-05-2008, 08:02 PM
Wow, it STILL won't start! I soldered it to the copper/brass magneto part, and nothing happened. When I let out the clutch, the motor tries to start, but won't stay running. When I pull the throttle, it revs the engine a little bit, but not much at all.
  #17 (permalink)
Old 06-05-2008, 08:16 PM
Norman's Avatar
LORD VADER Moderator
if its firing now as the way you are describing it you need to turn in the idle speed screw on the carb to increase the idle speed or hold the throttle open to get it to run and while blipping the throttle to keep it form dieing adjust the idle speed on the carb until it will idle.
norms-iron-works.tripod.com
  #18 (permalink)
Old 06-06-2008, 02:37 PM
spad4me's Avatar
You seem to have spark
Did you gap the plug.
Is the plug tight.
You need to check for air and gas now .
Turn your petcock so that the handle is parallel to the fuel line.
First push the tickler button about 30 times Yes its a lot.
Second Lift the choke lever UP .
Peddle down hill if possible at about 7 mph let go of the clutch while continuing to pedal.
When it starts keep it running at a low rpm not full throttle. slowly push the choke handle DOWN.
Are you pulling the throttle cable or twisting the throttle handle ???
Similar Threads
Best bike to start with? ran49 Pre-Motorized Bicycle Information. 54 Yesterday 02:44 PM
Bicycle Motor Refuses to start Mopedamauter79 Motorized Bicycle General Discussion 128 05-31-2008 02:06 PM
Trouble shooting the bicycle engine that won't start deacon Motorized Bicycle General Discussion 39 05-31-2008 01:31 PM
Won't start now!! Pablo Bicycle Engine Kits 26 05-07-2008 05:55 PM
What a relief it is to start instantly... Pablo Bicycle Engine Kits 14 03-05-2008 02:38 PM
