Originally Posted by swodell Wow, it STILL won't start! I soldered it to the copper/brass magneto part, and nothing happened. When I let out the clutch, the motor tries to start, but won't stay running. When I pull the throttle, it revs the engine a little bit, but not much at all. |
You seem to have spark
Did you gap the plug.
Is the plug tight.
You need to check for air and gas now .
Turn your petcock so that the handle is parallel to the fuel line.
First push the tickler button about 30 times Yes its a lot.
Second Lift the choke lever UP .
Peddle down hill if possible at about 7 mph let go of the clutch while continuing to pedal.
When it starts keep it running at a low rpm not full throttle. slowly push the choke handle DOWN.
Are you pulling the throttle cable or twisting the throttle handle ???
