Will This Cable Work As Replacement?
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. Cables For Go Karts and Mini Bikes I'm curious if this can be used as a replacement for the ...
Old 06-19-2009, 07:43 AM
MrLarkins's Avatar
HS Math Teacher
Default Will This Cable Work As Replacement?
I'm curious if this can be used as a replacement for the throttle cable.
Old 06-19-2009, 08:04 AM
Pablo's Avatar
Default Re: Will This Cable Work As Replacement?
I'm thinking the twist throttle side would be fine, but maybe not the carb side.
Why not just buy this:
Page Title
Old 06-19-2009, 12:09 PM
Norman's Avatar
LORD VADER Moderator
Go to wallmart and buy the bicycle cable set about $5.00 one of the cables ends will fit the throttle end for the end that goes into the carb you can make the end. I show how to make this end in my carb tear down post. Use silver solder and phone wire you will need a propane torch to get the cable and wire hot enough to do the soldering. You will also have extra cables for the clutch and brakes if you need them.
Norman
norms-iron-works.tripod.com
Old 06-19-2009, 02:02 PM
MrLarkins's Avatar
HS Math Teacher
Norman, I don't have that kind of equipment around here. And Pablo, thanks for the link, I ordered a few extra things while I was at it.
