| Sponsors
| Our Forums | | | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | When to change spark plug? Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. Hello everyone, I was just wondering.. After how long do you change your spark plug?
And what problems with the ...  |
10-08-2009, 03:27 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: Singapore
| | When to change spark plug? Hello everyone, I was just wondering.. After how long do you change your spark plug?
And what problems with the bike will point to a new spark plug?
btw i am riding a 80cc chinese engine.
Thanks  |
10-08-2009, 03:38 AM
| | Re: When to change spark plug? A worn electrode can happen eventually, but most people change plugs during a "tune up" - not specifically just these HT engines but a common practice. You can clean a plug if there is heavy deposits, there's even a lil tiny sandblaster unit made for this ($10) but I just get a new plug if it's that gooped up; - Harbor Freight Tools - Quality Tools at the Lowest Prices
Many 2 strokers (snowmobiles, ultralights etc.) usually start the season with a extensive tune up and a nice shiny new plug  Sorry I can't give you a definitive answer like mileage, but usage and things like mix ratios varies so wildly that each one is a lil different lol
10-08-2009, 04:10 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2009 Location: in the world
| | Re: When to change spark plug? i ran over 4000kms on my plug, never had a problem, once in a while i will soak it in gas to let it clean itself up
i'd rather have a bottle in front of me than a frontal lobotomy,
-linnix13(at)gmail,com |
10-08-2009, 10:51 PM
| | Re: When to change spark plug? I've read where the plug manufacturers warn against cleaning plugs. I think that is simply marketing. I've used the sand blast method and solvents and never had a problem. If the electrodes are not burned away, rare, and the porcelain isolator is in good shape, I can see no reason why cleaning a plug will not lengthen the life. After all, it isn't rocket science. Just metal and porcelain. If there is no shorting to ground a cleaned plug should be as good as a new one. But that's just me.
Over Youth and Skill |
10-09-2009, 07:19 AM
| | Re: When to change spark plug? just watch the gap, ive had a spark plug in an older engine a few years ago and the plugs gap kept getting smaller, i would re gap it once a week, turns out the metal was fatiguing from being regaped so much, the electrode broke of and fell into the engine, that was the end of that 2 stroke! so as a general rule, re gap when it needs it, and if you find yourself re gaping it often(more than 3 times) i would get a new plug,
10-09-2009, 07:46 AM
| | Re: When to change spark plug? Plugs do "wear out" but it takers a long time. The electrodes become rounded.
Clean your plug with a thin knife if there are deposits, (oily) or some 220 sandpaper (dry deposits) when or if you notice harder starting or lower performance.
You should have a look at the plug once in awhile to keep tabs on what's going on with your engine anyway, so that would be a good time to clean or replace the plug.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:15 AM. | | |
