wheel size and speed?
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. i have a 26" mountainbike and i can do around 20mph+ if i use smaller wheels how will it effect ...
Old 03-31-2009, 10:22 PM
Cabinfever1977's Avatar
Question wheel size and speed?
if i use smaller wheels how will it effect my speed and stuff?
Old 03-31-2009, 10:43 PM
Default Re: wheel size and speed?
This depends on the type of drive system used. A friction drive is not influenced by wheel size. A belt or chain drive system will tend to give lower top speed but more torque with a smaller wheel. This is assuming the same size is used for the other drive components. There are however other considerations; the main one being overall drive ratio. I would suggest that one immerse himself in the wealth of information to be found in these forums.
Old 03-31-2009, 10:54 PM
mechanickid's Avatar
a smaller wheel will make you go slower. if your going 20mph with your 26" you will go 15.10mph with a 20 inch.
its only too fast if you cant stay on!
Old 03-31-2009, 10:55 PM
assuming you have a standard china kit.
Old 03-31-2009, 11:08 PM
looks like i'll probally stick with my 26" wheels.
i was asking cause i have a 18" front and 16" rear wheel with a sprocket attached,these left over from my electric bike parts.
i have a 48cc dual start starfire II grubee frame mount.
my bike will do more than 20mph but i let off the throttle at 20.
but my $10 walmart speedo could be not working right,as it felt like i was doing 30mph or so and the speedo kept resetting itself.
i think i have a 41t sprocket on back.
the bike will go up a steep hill full speed,no problems at all.
Old 03-31-2009, 11:33 PM
i looked it up.
if i wanted to use the smaller wheels i would have to get a smaller 27T sprocket,in order to go the same speed.
Old 04-01-2009, 09:37 PM
Andyinchville1's Avatar
Manufacturer/Dealer
HI,
FWIW a 27T sprocket on a 20" wheel acts about the same as a 35T sprocket on a 26" wheel.....
Andrew
Sprockets now available in 9 anodized colors!
http://www.myspace.com/kingssalesandservice
http://www.youtube.com/watch?v=-zyU8n41f2c
Old 04-02-2009, 11:45 AM
Mrakulous's Avatar
I have 20" wheels on my 26" old schwinn frame. With the standard kit, i think I've gotten it up to 15-20 mph. I don't have a speedo, but the cars in my nieghborhood don't seem to pass me too fast. The spped limit is 25. That's my white Grand Marquis I'm not allowed to drive anymore.
  #9 (permalink)
Old 04-02-2009, 12:27 PM
thats a kool bike
  #10 (permalink)
Old 04-04-2009, 03:06 PM
How about taking a mountain bike with 26 inch wheels and installing 24 inch wheels? Would that be a good way to lower the bike, and lower the gear ratio for more power and less speed?
I have a Chinese Roadmaster mountain bike with 24 inch wheels, and I have another similar Chinese mountain bike with 26 inch wheels.
Of course the bike with 26 inch wheels has a larger frame too. I'd like to use the smaller wheels on it; and I'll have to modify the brakes to get them to work with the smaller wheels. But, I want a lower center of gravity, and I want a lower gear without having to change the rear sprocket. Wheel diameter will take care of that.
What do you think?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
