| Sponsors
| | | | | Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here! | Upgraded Roller Bearings Group Buy? Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Its my opinion that the chinese bearings offered on the 2 stroke kits offered by boygofast and other vendors are ...  | |
04-29-2008, 05:34 PM
| | Banned | | Join Date: Mar 2008
| | Upgraded Roller Bearings Group Buy? Its my opinion that the chinese bearings offered on the 2 stroke kits offered by boygofast and other vendors are inferior. I had an engine fail due to a roller bearing failure and I have read of a couple other people having same issue. I even think this occured on a Dax engine during a review of their engine if I recall correctly.
Anyway, I don't wish to buy new jugs in the future and was thinking about upgrading the bearings with Japanese ones.
I contacted VXB bearings and discovered that the appropriate sized roller bearing they sell is chinese made!
They can special order Japanese made bearings and would charge me $20 per bearing plus shipping (about 9.99 for shipping) for an order of 10 bearings.
Anybody want to do this as a group buy? I can't justify buying that many bearings at that price.
If so reply to the next message with your name and how many bearings you want.
Thanks! |
04-29-2008, 05:35 PM
| | Re: Upgraded Roller Bearings Group Buy? 1. Skyliner 1 bearing |
04-29-2008, 08:01 PM
|  | Manufacturer/Dealer | | Join Date: Dec 2007 Location: Charlottesville, VA
| | Re: Upgraded Roller Bearings Group Buy? HI Skyliner,
Would this rolller bearing fit the Dax 70 CC?
Thanks
Andrew |
04-29-2008, 10:39 PM
| | Re: Upgraded Roller Bearings Group Buy? Yes, its a direct replacement for the roller bearings on the engines. I bought two from VXB and they came in the mail. I was very disappointed when I confirmed my suspicion that they were Chinese made. I had gotten bearings before that were non-Chinese made but my source dried up and I'm looking for a new one. |
04-30-2008, 07:13 AM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: Upgraded Roller Bearings Group Buy? I would like to know if there is a bearing replacement for the bushed con-rod.
I know the new bearing won't retrofit where the bushing is.
04-30-2008, 07:41 AM
| | Re: Upgraded Roller Bearings Group Buy? What is the diameter of the hole in the con rod? A good machine shop shold be able to bore it out to the correct diameter. |
04-30-2008, 09:13 AM
| | Master Motorized Bicycle Builder | | Join Date: Feb 2008
| | Re: Upgraded Roller Bearings Group Buy? I have only had 6 engines returned under warranty in the past year. Only 4 were because of Roller bearing. 2 were from the same guy. and the same time. Not sure what happened there. Being such a low number, I do not see any problem with roller upper Bearing Dax motors. By the way, I just replaced Piston, ring and roller upper on my CR250 Honda. The Roller upper went on my CR250. Cost was over 200usd just for piston and ring for this Honda. No kidding. Oh.. This is Not a Chinese roller BTY. Also.. Keep this in mind. Going full throttle down hill will explode your engine. Roller or not. If you go down a hill full throttle and your engine does not explode, consider yourself lucky. Enjoy the ride.... |
04-30-2008, 09:33 AM
| | Re: Upgraded Roller Bearings Group Buy? Dax,
That doesn't tell us much because your warranty period is only 30 days. I'm wondering how many, not just your engines, fail later on down the road. I doubt most first time engine buyers get much riding on their engines during the 30 day period.
That's a good amount of money for a Honda piston and ring. Its a good thing that Hondas are very reliable. I've owned 3 Honda motorcycles in my life and they were extremely reliable except for an 84 700S nitehawk that had a starter clutch fail requiring me to split the engine case :-(.
Anyway, it was a boygofast engine. My Dax bushing engine had no problem going full throttle down the same hill. I've got numerous small 2 stroke engines that are being engines that spin up to 30,000 rpm continuosly with never a bearing failure. I don't think the stock bearings are up to snuff. Chinese metallurgy still has a long way to go...remember it wasn't too long ago that the engines had pot steel engine mount clamps that sheard when you torqued them down.
04-30-2008, 12:41 PM
| | Re: Upgraded Roller Bearings Group Buy? I don't know....I had almost 500 miles on my first one in the 30 day period.
I bought a bearing engine from that'sdax, haven't installed it, but it will be past the 30 day warranty when I finally do run it.
Am I worried? Nah.
05-01-2008, 11:35 PM
|  | Motorized Bicycle Builder | | Join Date: Apr 2008 Location: Omaha Nebraska
| | Re: Upgraded Roller Bearings Group Buy? HI all,
if I order an ThatsDax's engine, will that engine have the roller bearing?
am looking at it soon as I get tax income $$ | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:49 AM. | | |
