Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Tourque settings
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. I removed the head from one of my 70cc engines and I need to know the proper torque setting for ...
Old 02-10-2008, 07:21 AM
RedB66's Avatar
Default Tourque settings
I removed the head from one of my 70cc engines and I need to know the proper torque setting for the head bolts.
Old 02-10-2008, 08:31 AM
Norman's Avatar
LORD VADER Moderator
Default Re: Tourque settings
RedB66
110 to 120 inch pounds I have a post on top end work, shows the pattern, how I do the torque sequence. Hope this helps you
Norman
General Discussion on Motor Bicycles
Engine top end rebuild and an engine stand
norms-iron-works.tripod.com
Old 02-10-2008, 08:35 AM
Pablo's Avatar
Indeed 12 ft/lbs. Most brutish fellows don't have a torque wrench that accurately goes that low. Best to have a small 'en and a big 'en.
Old 02-10-2008, 11:14 AM
deacon's Avatar
I "borrowed" a torgue wrench from the auto parts store when I had to pull my head.
Old 02-20-2008, 03:41 PM
Bikeguy Joe's Avatar
You can approximate 12 ft/lbs. by grabbing a 3/8 drive ratchet at the "head" (do not grab it by the handle, you'll pull the threads out of everything you tighten!) and tighten it as tight as you can get it....if you're a brutish fellow.
