Throttle
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. How do one adjust it? Here? Here? What's the function of each?...
Old 11-25-2009, 12:32 PM
Default Throttle
Here?
Here?
Old 11-25-2009, 01:31 PM
Default Re: Throttle
Both can be used for adjusting the tension of the throttle control.I like to only adjust the tension on the throttle handle itself (if possible)
Old 11-25-2009, 01:43 PM
Bikeguy Joe's Avatar
You should use those to adjust the cable so there is a just perceptible amount of play before the throttle starts to pull the slide up.
In the first photo loosen the larger round, knurled lock ring, then turn the barrel out (counter clockwise) until you have about half of it in the top of the carb, then lock the lock ring.
Now do your final adjustment at the handlebar end.
Old 11-25-2009, 01:50 PM
turkman's Avatar
hey did that clutch arm come with your kit ? Or did you modify it?
Old 11-25-2009, 03:01 PM
It comes with my kit.
Old 11-29-2009, 07:39 AM
Humsuckler's Avatar
it came from zoom mine was teh same way, long and bent!
<code>"isuck@code"</code>
Old 11-30-2009, 11:19 PM
Hajuu's Avatar
haha same here, I thought it was pretty strange.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
