Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Is there a proper way to adjust the float in the (toilet) carb bowl?
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Continuing my saga……..(from the realm of electrics to fuel)………… Is there a proper way to adjust the float in ...
Old 03-24-2008, 10:15 AM
Pablo's Avatar
Default Is there a proper way to adjust the float in the (toilet) carb bowl?
Is there a proper way to adjust the float in the (toilet) carb bowl? Easy way?
Right now I have Norm's chalk board warning! (Yeah I know ) A factory setting that didn't work. Heavy fingers and needle nose pliers.
To Recap:
1) Factory setting, suspect float too low - not enough fuel ready to go. Open slide via twist throttle - too much air, not enough fuel on immediate demand. Not a matter of too rich or too lean.
2) Open carb up, tweak float "arms" apart. (see Norm's drawing). Problem gets worse.
3) Open carb up, tweak float arms together. Get Exxon Valdez of premix fuel in the garage.
4) Open carb up, tweak float arms apart problem still there, but better.
So today, this afternoon: Just bring the arms together a hair……it's a fine line and I need some input……..
Paco and his faithful black dog Chancho thank you immensely.
Old 03-24-2008, 10:30 AM
deacon's Avatar
Default Re: Is there a proper way to adjust the float in the (toilet) carb bowl?
you are way past anything I have done but good luck. I know you are one tenacious guy. I have nothing but admiration for you.
Old 03-24-2008, 10:51 AM
Pablo's Avatar
It's all in good fun. Gets a little irratating taking the carb off and taking ultimate care of the bowl gasket....but still fun getting my butt kicked by this sucker!
Old 03-24-2008, 11:32 AM
deacon's Avatar
Well mine didn't beat me but it sure a heck humbled me.
Old 03-24-2008, 01:28 PM
Well, you are on the right track thinking of it like a toilet bowl.
How about trying this:Take carb off, take it apart, hook up fuel line ,hold carb level and bend float until fuel level comes up to gasket level or a touch under.
Old 03-24-2008, 01:45 PM
Pablo's Avatar
Kinda what I tried when I did the spill....but it's a great way to see that the float valve is working. It's a bit difficult to eyeball. Maybe I should have a clear bowl fabbed
Old 03-24-2008, 07:06 PM
Norman's Avatar
LORD VADER Moderator
Don't you have a buddy who has one of these engines? Borrow his carb and try it to see if the problem goes away. You could send me your carb and I'll give it a go make it work on mine then send it back to you. heck box it all up and I'll get it to run or shoot it and put it out of its misery.
Norman
norms-iron-works.tripod.com
Old 03-24-2008, 08:25 PM
Pablo's Avatar
OK so I came home and adjusted the float, just ever so slightly UP (float higher, arms together) - wholly crap it runs MUCH better I mean I was revving the caca out of it - then after it's fully warm choke all the way off still running good, getting warmer and hit the throttle hard booooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooggggggggggggggggggggggg ggggggggggggggggggggggggggggg AND dies.
POINT = I'm getting somewhere! Just ate, need to have my cheesecake then take the carb off again....
  #9 (permalink)
Old 03-24-2008, 08:33 PM
Pablo's Avatar
Almost forgot when it died it back fired and and nice explosion up the intake manifold...blew smoke out the carb.....
  #10 (permalink)
Old 03-24-2008, 08:42 PM
Ilikeabikea's Avatar
Pablo did you say your mag wasnt tight on the woodruff key?? That could sure cause a timing issue and it sure sounds like you got a timing issue................
http://www.galtx.org/
http://bdconner.com
Similar Threads
proper seat adjustment CRUISER Pre-Motorized Bicycle Information. 6 03-14-2008 06:17 PM
Super Bowl Sunday Ride. Easy Rider Travels and Adventures 0 02-03-2008 08:52 PM
installing carb on manifold Norman Bicycle Engine Kits 0 01-16-2008 06:56 PM
