| Sponsors
| | | | | Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here! | Terminal Affliction? Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Well,shortly after celebrating 1000 hard miles on my boy go fast 70cc.in 3 months,I'm afraid she ...  |
06-06-2008, 04:03 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: So.In.
| | Terminal Affliction? Well,shortly after celebrating 1000 hard miles on my boy go fast 70cc.in 3 months,I'm afraid she throwing in the towel.
First I noticed thick black oil under the motor after setting over night and at first thought it was coming from the exhaust.Then the speed at which vibration begins began to drop.From 27 to 22 MPH.Now I notice the leak seems to be coming from behind the drive sprocket.Broken seal maybe? Lot of ominous noise as well.
I ordered a new lower unit from Dax which I plan to run while attempting to rebuild the first .Anyone else experience these symptoms.Thanks,Ron |
06-06-2008, 04:17 PM
| | Re: Terminal Affliction? Sounds like something not good is going on. Maybe when you get it tore down it won't be anything major............................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
06-06-2008, 04:36 PM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: Terminal Affliction? This might help when you rebuild it. Or to find the bad part. Sounds like a shaft seal- there are two I think... (no. 14?)
__________________ If it ain't broke, and you mess with it long enough, it will be.
06-06-2008, 05:22 PM
| | Re: Terminal Affliction? Bikeguy:Thanks for the link.I know there are some seals in there somewhere from Norman's rebuild thread.I found this diagram which doesn't show them Clutch Assembly
I should have said in my first post that I ordered the complete motor from Dax minus the rest of the kit.So I will be up and running while I pester you guys with silly questions.I saw where Dax bumped his kit price $50.00,so I jumped on the spare motor before increase trickles down.Thanks Ron |
06-06-2008, 05:23 PM
| | Re: Terminal Affliction? Very good sir.
06-06-2008, 08:21 PM
| | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Daytona Beach
| | Re: Terminal Affliction? Hope you can find all of the parts to rebuild it. Where are you going to find the parts? |
06-06-2008, 09:34 PM
| | Re: Terminal Affliction? sisdavid
I would think the problem involves the seals ,bearings or both.The link I posted above list individual parts with price.Although they don't list seals. Clutch Assembly
I have an extra set of rings,but I don't think thats the problem.Heck,I just figured I'd ask Norman.Ron |
06-06-2008, 11:37 PM
| | Motorized Bicycle Apprentice | | Join Date: Jun 2008
| | Re: Terminal Affliction? Quote:
Ron,
I would venture to guess your jackshaft bearing is going south, all the kits I have came with cruddy china shielded bearings, fairly easy to replace with sealed SKF units you can get from any local bearing company. The only seals in that engine are on the crank, and they are most likely shot as well, but are probably not the root cause of your problem. |
06-07-2008, 07:09 AM
| | Re: Terminal Affliction? Mako,
Thanks for the info.I made a copy of your 20 point rebuild post.If I manage to get all that done,it should be much better than new.Ron | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 01:35 PM. | | |
