| Sponsors
| Our Forums | | | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | T mounting bracket Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. So... I did not get that bracket in my box but was asking, does that bracket help keep the bike ...  |
10-28-2008, 08:54 PM
| | Motorized Bicycle Member | | Join Date: Oct 2008 Location: Bay Area, California
| | T mounting bracket So... I did not get that bracket in my box but was asking, does that bracket help keep the bike from vibrating?
What other benefits does this mounting bracket help with?
Thanks |
10-29-2008, 02:27 PM
| | Re: T mounting bracket anybody know what these brackets really do? Im going to look all over and see just how many people have these brackets. |
10-29-2008, 03:03 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: CT, U.S.
| | Re: T mounting bracket Not sure which bracket you mean? One of the drill threw your frame ones?
Work like you don't need the money, Dance like no one is watching and Love like you've never been hurt I want 2 ride my bicycle |
10-30-2008, 03:20 AM
| | Re: T mounting bracket No. I will give you al link to it. http://motorbikeworks.com/directions...ions%20PDF.pdf
It is page 15.
And also when I put my sprocket on the bike does it need to rest fully on the spokes or can it rest close because I am going to put the rubber pad on it anyway. In the directions it also says I need to file the hole in the spokes bigger so the sprocket can rest on the spoke.
Thanks for any input on this  |
10-30-2008, 04:35 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Mesa Arizona
| | Re: T mounting bracket That is a bracket that Livefastmotors kits use to mount the motor to the down tube of the bike. Do you have a LiveFastMotors kit? If not you will have some other way to mount the motor. You definately need to mount at least 2 places to have a secure motor. The sprocket mounts on the hub with the rubber/fiber disk inside and outside of the spokes sandwiching the spokes. The sprocket does not touch the spokes but the rubber piece.
LennyHarp of Lenny's Bikes & Things http://lennyh.com
10-30-2008, 04:49 AM
| | Re: T mounting bracket Oh, if you do not need it, your better off. step 21 shows it well. Is to correct for large down tubes.
10-31-2008, 06:34 AM
| | Re: T mounting bracket Well... I have a large down tube and tonight I tried to put the engine in and need that bracket. Does anybody know of another way to fit the motor mount around a big tube? Im starting to think that the T bracket is kinda lame. As in it does not look cool. |
10-31-2008, 06:42 AM
| | Re: T mounting bracket It's not lame if it works and it will if you fit it carefully. Here is datz510's solution to oversized tubes that will take a little more skill and effort to build, but is nicer... Rotten Orange build - Gary Fisher Aquila shifter buildup!
10-31-2008, 08:52 AM
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:16 PM. | | |
