Re: speedometer well, the speedo's work with magnetic pickups.. as the magnet passes the pickup, a small voltage is induced.. if your getting feedback from the engine into the pickup.. try mounting the pickup on a small peice of rubber to isolate it... could also be getting induction from the plug wire, in which case the plug wire has a bad case, or the speedo wire runs close to it... attached to front wheel or back wheel? |
