Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Gas Bicycle Engine Kits
Gas Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Spark plug replacement
Discussion at Motorized Bicycle Engine Kit Forum in the Gas Bicycle Engine Kits forum. Antiseieze Norm swares by it i do as well. A little dab on the threads to plug works great. Do ...
  #21 (permalink)
Old 08-28-2008, 11:36 PM
goat herder's Avatar
Default Re: Spark plug replacement
Antiseieze Norm swares by it i do as well. A little dab on the threads to plug works great. Do not want it on the electrode. A little bit goes a long ways. As Norm said pretty soon you've got the sh^*** all over you!
  #22 (permalink)
Old 08-29-2008, 12:56 AM
Motorized Bicycle Apprentice
I have a big tub full of anti-seize lubricant!!! Stuff is made by permatex, and yes, just a little will do. I put the stuff on my lawn mower muffler threads and man it makes a lot of white smoke!!!
  #23 (permalink)
Old 08-29-2008, 02:02 AM
Lightbulb Re: Spark plug replacement
You could always use a thread chaser or tap to remove the carbon build up from the head(engine top). carb cleaner can help too.
  #24 (permalink)
Old 09-28-2008, 01:29 AM
Hey, here's a crazy Idea!!! Use an Iridium IX Plug!!! BPR7HIX
Mine's an old beach cruiser, go ahead, laugh... ...I don't care if you think its goofy, I'm riding it anyway!!!
  #25 (permalink)
Old 09-28-2008, 04:20 PM
Dan's Avatar
Dan Dan is online now
When we speak of gap, is that in inches?
Normalcy ain't what it used to be.
  #26 (permalink)
Old 09-29-2008, 05:25 PM
Originally Posted by misteright1_99 View Post
NGK B6HS Burns clean and lasts.....
I'm using the same plug, not really sure what the gap is that it came as, and what it should be set to ? So, I am guess ing it doesn't come already gapped for my 80cc Chinese ?
Mistright1, I am down to the plug the wire or did something go wrong with the gas mixture, while just sitting there, other than the fact the weather has changed a little and I am at sea level, I am running with the stock carb accelerator setting, that I have not changed, but am willing to.
I am still getting loss of power not so much bogging down, but the power isn't where it was. It is like it is missing, or not firing exactly right, this occurs only when in motion and accelerating. Kind of a rough ride like you are riding the RR ties, but not actually that drastic.
Can you give me a gap spec. I should be using ?
The last tank which was I believe my fourth gallon was 30-1 per Kings,
I used Valvoline 2 Cy. Multi-purpose.
Last edited by Wheel Rush : 09-29-2008 at 05:39 PM. Reason: spell + addirional comment
  #27 (permalink)
Old 09-30-2008, 09:05 AM
Bikeguy Joe's Avatar
MODERATOR
Gap @ .020-.024"
Sounds like you are running too rich, try the needle clip up a notch or two. (second from top or top notch).
  #28 (permalink)
Old 09-30-2008, 09:53 AM
velardejose's Avatar
Hi
I installed a B6HS spark plug yesterday night
Stock plug was LD Z8C
Both were gapped at 0.6 mm (0.025'')
First impression: climbed a hill easier than before (needed some pedaling help before)
Today, the engine needed more time to get hot
Then I had to adjust the idle screw more than a full turn to keep the engine running
Seems to run better at high revs, but that could be sujective
Peace
PD Insulator nose length was shorter in stock plug, but b6hs seems cooler (???)
Advertisers
