Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Spark plug replacement
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. I'm going to fire mine up with a B7HS - just for ****z and giggles. I got it for $1. ...
  #11 (permalink)
Old 05-26-2008, 05:18 PM
Pablo's Avatar
Default Re: Spark plug replacement
I normally run a B5HS with no issues, so I'll let you know how a plug two steps cooler does. (not necessarily a smart move)
  #12 (permalink)
Old 05-26-2008, 07:14 PM
Pablo's Avatar
The B7HS did just fine....if anything, once warmed up it pulled a bit better.
  #13 (permalink)
Old 05-27-2008, 04:53 AM
First picture is of Dimonfire do not know what number, but is the Cj7y champion equivaliant. Second red arrow is the stock plug. See how the stock plug reaches all the way down, and the Dimonfire does not. I get carbon on the last 2 or 3 threads which makes it really hard to screw in the regular length plug because of carbon. You would have to take the top part of your engine the part that the plug goes into and scrape carbon off to go back to a regular length plug.
  #14 (permalink)
Old 05-27-2008, 04:58 AM
Originally Posted by toytime View Post
I am now going with a Champian L86c and I love the new sound I seem to be getting.
The plug is a bit too long and I may end up with probs. when I go to remove it but it did change the sound and feel of the bike, almost as if it is running a little richer now, from the sound of things. I have also used the "40501" which is what I seem to remember being an NGK but looking at it now, there is no "ngk" marking.
Toy Time a longer plug may creat a sittuation that requires you to take the top part of your head off to take the plug out because of carbon.
  #15 (permalink)
Old 05-27-2008, 05:28 AM
Bikeguy Joe's Avatar
So then the Champion CJ7Y is off the list.
  #16 (permalink)
Old 05-27-2008, 05:30 AM
I have had very good results with the Autolite plug.
  #17 (permalink)
Old 05-27-2008, 07:40 AM
I think the CJ7Y Champion should be off of the list because if you go back with a plug with the longer threads you have to take the head off to get the carbon off
  #18 (permalink)
Old 05-27-2008, 11:59 AM
fairracing31's Avatar
Just a reminder, I alway's use thread ant-sieze on my plug.
  #19 (permalink)
Old 05-27-2008, 02:42 PM
Always! And never remove a very hot plug.
  #20 (permalink)
Old 08-28-2008, 09:22 PM
Motorized Bicycle Apprentice
I have two engine kits. I have a 50 and an 80. The Chinese plug that came with the 50 had a reference number to NGK BP7HS. I have successfully used NGK BPR7HS and an Autolite 4123. Great Plugs. Does anyone know how long a plug should last (in general)? I've been running the Autolite 4123 for almost a year and it hardly has any erosion on the center electrode.
Similar Threads
Spark plug wire and boot. ran49 Motorized Bicycle General Discussion 12 04-01-2008 02:39 PM
Loss of high RPM spark? Pablo Bicycle Engine Kits 93 03-28-2008 11:14 AM
Bicycle Motor Spark Problem? buttburn Motorized Bicycle General Discussion 28 03-13-2008 05:30 PM
bicycle motor spark plug wire replacement CRUISER Bicycle Engine Kits 1 03-13-2008 06:29 AM
Troble shooting bicycle engine cdi and spark plug wire deacon Motorized Bicycle General Discussion 19 01-23-2008 09:58 PM
