2 Stroke Bicycle Engines & Kits2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here!
smelling like gas
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. is it possible to ride one of these china girls and not smelling like gas? I mean personally i dont ...
is it possible to ride one of these china girls and not smelling like gas? I mean personally i dont always mind and enjoy the smell of my chine girl but sometime ill ride it to the store happen to see a pretty pice of a** i know and would rather not smell like gasoline while talking to her
A custom exhaust system that puts the tail pipe behind you, close to the rear wheel will help. Some of us have built such systems using 1/2 or 3/4" electrical conduit. You need access to a welder or someone who can weld or braze the pipe for you and a method of bending the pipe such as a conduit bender. Hope this helps
Over Youth and Skill
i just ordered a expansion chamber from sbp wich im sure im gonna bomabrd this site with questions once i get it, you think that would do the trick and i also herd the have lots of exhaust leaks would muffler putty help or just fall apart due to vibration i dont se it withstanding those kind of conditions it hardly works on cars
BTW - if yer referring tp the SBP system having "lots of leaks" I've no idea where ya got that info, mine is as tight as the day I installed it and I've not had any problems at all
wow xlite thats a good one it honetsly made my day im sure ill still be laughing about it tommorow :P and im glad to hear that there are no leaks from the sbp pipe i was ready to have to tinker with it forever
I got over 1000 miles on my SBP pipe so far and no leaks. They say the silly-cone tubes deteriorate but no sign of that yet either.
at any auto parts store get a tube of Copper Plus Heat Resistant Gasket Maker and coat both sides of the exaust gasket. snug it fairly tight and leak solved. you do have to reappy if you remove the muffler.
i install these kits for a retired income and do this with each install.
