Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Seized Piston
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Lately my motor seemed to have lost power. Today the piston seized. I took it home, took off the head ...
Old 04-09-2008, 03:53 PM
bgoates's Avatar
Unhappy Seized Piston
Lately my motor seemed to have lost power. Today the piston seized. I took it home, took off the head and taped the piston and it came loose. Put head back on started up and minutes later seized again. I don't think it is because I'm running lean because I mixed 25:1 and spark plug, piston, and cylinder are all black. Anybody have any solutions before it seized permanently ?
Thanks
Old 04-09-2008, 03:59 PM
Bikeguy Joe's Avatar
Default Re: Seized Piston
How many hours on the engine?
Excessive carbon build up? Sticking rings can cause a seizure.
Are you absolutely sure the plug itself is black? That would be too rich, not a cause for seizure.
Old 04-09-2008, 04:47 PM
VENICE BOY's Avatar
Custom Builder / Dealer
I would say to take the barrel off too & look at the rings & piston skirt & inside the barrel.
Look for ANYTHING that doesn't look right...how do the rod bearings feel? any exessive play?
Tell us what you find!
Check out www.VeniceMotorBikes.com
Old 04-09-2008, 05:15 PM
bgoates's Avatar
Yes the plug is black. How do you take the barrel off ?
Old 04-09-2008, 05:29 PM
VENICE BOY's Avatar
With head off & the engine out of the bike, slide the barrel straight up off the piston.
You might have to (CAREFULLY)tap it loose with a rubber mallet, don't break the cooling fins!!!
Old 04-09-2008, 05:55 PM
bgoates's Avatar
I got it started again and ran a few km's but kind of hesitant to take it for a good spin. Is there anything I just could spray into the cylinder to clean out all that carbon without taking everything apart ?
Old 04-09-2008, 05:56 PM
Yeah, see if there are any vertical marks on the cylinder liner or piston...may be a wrist pin bushing that went bad....how many hours on it?
Old 04-09-2008, 06:57 PM
deacon's Avatar
Tell me you torqued the head bolts carefully.
I have a question though. If the cylinder walls are scored, wouldn't that mean the compression would be down too much for it to start at all. If so he can rule that out since it did start again.
  #9 (permalink)
Old 04-09-2008, 08:24 PM
deacon's Avatar
I have one more question did the motor lock up when the piston seized.
  #10 (permalink)
Old 04-09-2008, 09:58 PM
bgoates's Avatar
Yes the motor locked when piston seized and tire skidded.....I don't have a torque wrench so just tightened with a socket wrench.
If I'm running rich do I move the clip on the carb needle up or down ?
Should cylinder and piston be black as coal ?
I think my compression is still good...
Thanks for your comments.....
Similar Threads
Piston Reading 101 Andyinchville1 Motorized Bicycle General Discussion 2 01-19-2008 06:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
