Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Gas Bicycle Engine Kits
Gas Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Running REALLY rich.....which way...
Discussion at Motorized Bicycle Engine Kit Forum in the Gas Bicycle Engine Kits forum. She runs, but man I'm killing it with fuel - dumb question which way should I move the clip to ...
Old 01-20-2008, 03:14 PM
Pablo's Avatar
Default Running REALLY rich.....which way...
She runs, but man I'm killing it with fuel - dumb question which way should I move the clip to make it leaner?
Old 01-20-2008, 03:20 PM
Norman's Avatar
LORD VADER Moderator
Default Re: Running REALLY rich.....which way...
drop the needle down. stock is #2 spot up from the short end. For example the c-clip on the last groove closest to the taper is richest and c-clip on the every end is leanest. Does that help and make since? I need to get a picture. As it would explain it best.
Norman
Old 01-20-2008, 03:29 PM
deacon's Avatar
Think of it like a stopper.
the longer the stopper the better the seal... So when you move the clip UP toward the flat end the rod, it becomes longer and goes farther into the seat making a better seal.
If you move the clip toward the pointed end then you prevent the stopper from going into the seat as deeply letting more gas by it.
More gas toward the point ... less gas toward the back.... Probably not as good as explaination as some but it tends to make it easier for me to remember ...
but it dont help me get the darn carb to work.
visit my blog for Riding in the hood,... The home brew bike journal....http://frictiondrivebicycles.blogspot.com/ The deacon's fiction
Old 01-20-2008, 04:46 PM
Pablo's Avatar
What you guys say make total sense......so I moved the clip up and it's still flooding and won't even start!
So I think something is fundamentally wrong with the carb set up...let me ask this: Does the washer with the slot in it go OVER or UNDER the E-clip when you reassemble it?
The picture in the Mandarin instructions clearly show it UNDER (which doesn't seem correct), but when I read on the (ahem) other board one smart guy says it goes OVER the E-clip when you reassemble it......and in some ways that makes sense...
Old 01-20-2008, 05:30 PM
Norman's Avatar
The needle and e-clip goes in first then the slotted washer next so the slotted washer goes over the needle and e-clip.The spring and the slotted washer hold the e-clip and needle in the slide.
You might have a sticking float to cure that take off the float bowl and remove the float assembly so you can get to the seat and needle thats in there blow this out with compressed air no wire or pins should be used to clean this out as you will wreak it. If you've got the carb off the bike you can turn the carb upside down and the floats assembly should for the most part look level. to see if the floats needle and seat are working . use a piece of fuel tubing and gently with our mouth blow into the fuel tubing should takes a little pressure to make the needle unseat and if you put your finger on the float assembly and blow you should not be able to.(Sounds Kinky) Does this help? If not I'll have to get out the camera.
Old 01-20-2008, 06:23 PM
Norman's Avatar
Here the pictures of the carb and how it goes together I also made a mistake my engines both have the e-clip in #2 slot from the top or short end. Pictures will help explain.
Old 01-20-2008, 06:24 PM
Norman's Avatar
Old 01-20-2008, 06:25 PM
Norman's Avatar
Where my e-clip is on the needle both the 70cc and 80cc are the same and I think factory stock
  #9 (permalink)
Old 01-20-2008, 06:27 PM
Norman's Avatar
What it looks like just before you put in the spring and cable
  #10 (permalink)
Old 01-20-2008, 06:35 PM
deacon's Avatar
Hold on do I have mine assembled backwards. Does it not go from the shallow end through to the deep end. It looks like yours goes through the deep end to the shallow end.
never mind I think now i have it. I flipped the brass pipe over and now it all makes perfect sense. Dang it Norman I can't believe my mind is that soft that I couldn't see what was going on. Geeze now I'm ashamed to show my face here.
Advertisers
