Replace cross shaft w/o splitting cases? After a lot of tinkering on my 48cc 2stroke, I have determined that the cross shaft, that connects the clutch to the chain sprocket (through the motor) is bent. It manifested as a clutch that wouldn't release, a lot of crankcase racket and increase in visible wobble in the chain sprocket AND the clutch assembly.
Can I replace the shaft assembly without splitting the cases?
If not, I may purchase a new motor and repair the engine with the bent shaft as time allows.
I read thru Norm's teardown and buildup and it seems to indicate that the cases will need to be cleaved to repair this.
Any advice is appreciated.
"Don't believe everything you read on the internet. That's how World War I got started" - PS3 commercial |
