Pk80-j Limited Edition Slant Head Teardown And Review
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. the cross hatch will never go away its there to keep oil in it I'm sure you know that. my ...
  #21 (permalink)
Old 11-21-2009, 05:54 PM
Banned
Default Re: Pk80-j Limited Edition Slant Head Teardown And Review
the cross hatch will never go away its there to keep oil in it I'm sure you know that. my cr250 has over 200 hrs on it and the hatch is still there..
  #22 (permalink)
Old 11-21-2009, 08:48 PM
Actually i was under the impression that the crosshatch had alot to do with how the engine broke in.
Far as i know the old time engines took longer to break in due to the deep crosshatch.
Now 4 cycles i know will allways have the crosshatch.
But these 2 cycles i wonder.
My Grubee hardly has Crome left in the bore let alone Crosshatch.
But it has seen better days.
  #23 (permalink)
Old 11-24-2009, 10:48 AM
Zenoptic's Avatar
I just ordered one! What is the proper head torque for these heads?
  #24 (permalink)
Old 11-24-2009, 12:51 PM
Thats a good question.
Here is a good answer.
Proper Bolt Torque - by Zero Fasteners
Now i have seen some reccomendations around here somewhere.
I'll have to find it.
  #25 (permalink)
Old 11-24-2009, 12:54 PM
Heres one more in a more critical application.
Rotax engine torque specifications, Rotax cylinder head torque specs, Rotax aircraft engine bolt torque specs.
I would say 60 inch pounds.
Just be extra careful not to drive the stud to the bottom of the tapped hole and then turn it more.
That will certinly strip the threads out.
Actually push the threads out.
  #26 (permalink)
Old 11-24-2009, 01:44 PM
Zenoptic's Avatar
I will locktight (Blue) the studs and hope that helps. 60Lb sounds good thanks.
Do you think this engine needs a Nut & Bolt upgrade?
"When the going gets weird, the weird turn pro"
H.S.T.
  #27 (permalink)
Old 11-24-2009, 02:21 PM
The HeadStuds look good to me.
The rest i will replace with some nice Socket Head Cap Screws.
There easier to tighten and to take out.
Should only cost about $10.00 for all the bolts.
And i Like Nylon Insert Lock Nuts so i'll prolly get thoose too.
Other than the head studs the rest look the same as any stock motor.
The Flat head screws i have are allready partially stripped.
I had to use an impact driver to get the engine apart.
  #28 (permalink)
Old 11-28-2009, 11:51 PM
Banned
i just built a skyhawk with all pk guts crank, sealed main bearings,pk top end head ,cyl,piston pirates intake wow this thing revs i raised the ex port .5 mm and widened it .5mm each side and tapered the port didnt lose any bottom end either and it def rvs atleas 8k
  #29 (permalink)
Old 11-29-2009, 02:18 PM
I as well did slight porting.
Lowered the intake a little and raised the exhaust.
Matched the crankase and tranfers.
gonna use thin aluminum base gasket.
I have the bottom end back together.
I was putting the top end together and broke a ring.
Waiting for a new set from Justin.
Should have her up and running soon.
I'll post pics.
  #30 (permalink)
Old 12-06-2009, 02:00 AM
Zenoptic's Avatar
Mine had two head gaskets on it. did yours come this way?
H.S.T.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f4/pk80-j-limited-edition-slant-head-13117.html
Posted By For Type Date
thrust washer This thread Refback 12-11-2009 12:28 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
