Re: No fuel flow- Carberator problems If it doesn't fire on easy start spray, you may not have spark.
Check for spark first. Then if you have spark, check that you fuel is flowing into the float by pushing down the tickler for a second or two, and if fuel is flowing, you will definitely smell/see it.
If you then have confirmed spark and fuel, pull up the choke 3/4 of the way and pedal it hard, pop the clutch while working the throttle a little.
