| | NGK BR4HS - Iridium or other upgrade? Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. My 80cc takes a NGK BR4HS. Currently there is a Chinese cheesebo equivalent plug in there.
I was just wondering ...  | |
01-13-2008, 09:00 AM
|  | Amsoil Dealer | | Join Date: Dec 2007 Location: Duvall, WA PNW
| | NGK BR4HS - Iridium or other upgrade? My 80cc takes a NGK BR4HS. Currently there is a Chinese cheesebo equivalent plug in there.
I was just wondering if anyone could cross reference the NGK BR4HS to an even "better" plug? |
01-13-2008, 09:18 AM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: NGK BR4HS - Iridium or other upgrade? here is a nice guide for cross referencing Spark Plug Part-Number Interchange Guide, Home
hope that helps. i do not know enough about each plug to recomend the best but lots of good info on that site
01-13-2008, 09:40 AM
| | Re: NGK BR4HS - Iridium or other upgrade? Nice cross ref. - but not NGK - NGK cross. I love the guy's site though. Bookmarked! |
01-13-2008, 10:34 AM
01-13-2008, 05:32 PM
| | Re: NGK BR4HS - Iridium or other upgrade? You can't get much worse than the plugs that come with these from China.
You can't get much better than an NGK.
Bosh platinum maybe....
Anything else is just throwing away money IMHO. |
01-14-2008, 01:08 PM
| | Re: NGK BR4HS - Iridium or other upgrade? Quote:
Originally Posted by Bikeguy Joe You can't get much worse than the plugs that come with these from China.
Anything else is just throwing away money IMHO. | Deadly correct.
I can even say that a Bosch Platinum is not better than an NGK.
Anyways I emailed NGK and they responded: Quote:
Unfortunately at this time we do not have anything available. With the
1/2" thread reach plugs there are only standard nickel plugs available.
There is an iridium IX series BR6HIX available, but is so much colder
that it will most likely foul out pretty quickly. Thank you.
01-17-2008, 12:27 PM
| | Re: NGK BR4HS - Iridium or other upgrade? Guys
I'm still running the plug that came with the engines kit it starts right up and runs smooth with the nice brown color on its insulator. So find out whats a good one so when the time comes that I have to look for a new plug I won't have to look far and hard.
Norman |
01-17-2008, 12:48 PM
| | Re: NGK BR4HS - Iridium or other upgrade? I don't think you will go wrong with NGK. My instructions call for BR4HS. You could use this if you have a 70-80CC. Or non-resistor B4HS. OR you could step down one heat range to the B(R)5HS.
BR6HIX - I may try it....... |
01-17-2008, 11:12 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jan 2008 Location: Nor*Cal
| | Re: NGK BR4HS - Iridium or other upgrade? I've used NGKs for many years/decades in my jetski, scooters and karts but as of last year I've switched to Autolites. I think NGK went thru a phase where their plugs were easily fouling up and going bad. (But that was 2 years ago) I found a box of B6HS plugs that are at least 10 years old. They are the ones with the gold/yellow coating. I've been using them in my bike. I know they are a colder and longer plug but it works fine and I have a little bit more bottom end. |
01-17-2008, 11:23 PM
|  | Dealer | | Join Date: Dec 2007 Location: Sacramento
| | Re: NGK BR4HS - Iridium or other upgrade? Hi the B6HS is a good plug for MOST of these engines, tho some may lack the clearance above.
In some of these engines, the stock plug does NOT fill all the threads.
2-strokes love colder plugs as long as they do not easily foull out.
Mike
__________________ www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:51 PM. |
