Make your Clutch Easier to Pull
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. Take the plate the clutch arm is in off. Leave the clutch push pin and bearing in the clutch shaft. ...
Old 06-07-2009, 02:48 AM
Junster's Avatar
Default Make your Clutch Easier to Pull
Take the plate the clutch arm is in off. Leave the clutch push pin and bearing in the clutch shaft. Rotate the clutch arm till it will slip out of the housing. At the bottom there's a flat in it. Take a dremel and round off the back edge of that flat. Not to much just radius it. If you hold it with the flat end pointing up it's the right edge. That's the edge that pushes the clutch pin. Put a little grease on the whole thing and put it back together. It makes the clutch pull alot easier and smoother.
Put something FUN between your legs..
Old 06-07-2009, 09:45 AM
Default Re: Make your Clutch Easier to Pull
good idea...i'll try it and let you know...thank you...Dennis
Old 06-07-2009, 12:48 PM
misteright1_99's Avatar
Another solution is to lengthen the arm, pop the arm off the rod, find some tubing (I used copper) and slide over the arm to make it longer (just about 1 inch) rotate the arm inward and reinstall on the rod.
Old 06-07-2009, 01:57 PM
i have a long and bent one i got on a 50slant i got from BGF...it works great...always new ideas...thank you...Dennis
Old 06-07-2009, 02:16 PM
hey mister right, what is that on the intake pipe? and what is that black box on the right side of the pic??
Old 06-07-2009, 03:14 PM
Cabinfever1977's Avatar
take the spring off the cluctch lever and storten the cable if its real long and it will be very easy to pull.
Old 06-07-2009, 03:22 PM
i think that is a alarm for his bike....i use to have one for when i took my bike to work...ha...it makes a cherp sound...at least you know someone cares...ha...what i want to know is how misteright1 99....how you fabricated the intake filter....thats sweet...thanks for the pick...Dennis
Old 06-07-2009, 03:30 PM
i like his intake filter too i think he got it off something else. i made one using a rubber boot from a bike shock and 6" aluminum pipe.i ran the hose to the carb and turned it around the side of engine and taped a aluminum pipe to it and pointed in frontward and tied to clutch cable,its like a forced air intake.
make-your-clutch-easier-pull-photo002.jpg  make-your-clutch-easier-pull-photo004.jpg  make-your-clutch-easier-pull-photo005.jpg  make-your-clutch-easier-pull-photo031.jpg  make-your-clutch-easier-pull-photo011.jpg
  #9 (permalink)
Old 06-07-2009, 03:35 PM
reg454's Avatar
Or you could make on of these in about 30min.
  #10 (permalink)
Old 06-08-2009, 11:33 PM
The intake was tapped for a boost bottle which I dont use anymore.
The filter consists of a 3/4" pvc elbow, part of a cover off a can of spray paint, and a dish strainer
make-your-clutch-easier-pull-asst-pics-008.jpg-resize.jpg  make-your-clutch-easier-pull-carb-filter-july-08-004.jpg-resized.jpg  make-your-clutch-easier-pull-carb-filter-july-08-002.jpg-resize.jpg
