| | | Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here! | Just bought 4 stroke Chinese bicycle engine frame mounting kit Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. I had over 500 miles each on two different bushed engines and they were/are fine....  | |
02-15-2008, 06:35 PM
| | Re: Just bought 4 stroke Chinese frame mount kit I had over 500 miles each on two different bushed engines and they were/are fine. |
02-16-2008, 01:08 AM
|  | Master Motorized Bicycle Builder | | Join Date: Feb 2008 Location: Metro Washington, DC
| | Re: Just bought 4 stroke Chinese frame mount kit I have a spare 3 hole sprocket plate that I'd be happy to send you. PM me with your address if you are still looking for one. I can also photocopy the instructions that came with mine. They aren't the best instructions, but they cover the basics.
Hint: If you contact the folks at bicycle-engines.com, and let them know you ordered the kit from Revolutions and are having issues, they may help you out. They supply Revolutions with some if not all his kits.
Believe it or not, it's is all worth the effort  |
02-16-2008, 05:58 AM
| | Re: Just bought 4 stroke Chinese frame mount kit You da man AC! |
02-16-2008, 08:10 AM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: Just bought 4 stroke Chinese frame mount kit now this is what this motorized bicycle forum is all about. autocycler  definatly gets thumbs up from me |
02-16-2008, 09:40 AM
| | Re: Just bought 4 stroke Chinese frame mount kit Don't forget biker guy joe and his chain for an old man project... All the guys here seem to be willing to share information and stuff. |
02-22-2008, 01:46 PM
| | Motorized Bicycle Apprentice | | Join Date: Feb 2008
| | Re: Just bought 4 stroke Chinese frame mount kit Quote:
Originally Posted by nogoodnic Sorry, I thought you had a 2-stroke too, we'll still try to help where we can. I am courious about this engine also.
The mount for the wheel should be the same as the 2-stroke type, one thing I noticed this in your original post:
. Next, I find the sprocket kit only has 2 half moon clips when there should be 3. And one of the round rubber spacers had 2 big chunks gone out of it.
There are two diffrent types of plates for mounting the sprocket, one set is a 2-piece that is two half circles, and the other is a 3-piece in thirds. I have recieved kits with either of these types or both. When I can I use both layers pf plates layered so that there are no seams to the rubber and everything tightens down more evenly. For the rubber spacers, do you have the solid black rubber or are they cut out of old tires? The solid rubber is junk and crumbles over a short period of time, the tire ones are much more durable and I have never had a problem with them...Kelly | The rubber is the rag type rubber. Didn't know they even made a cheapy version of these things. I was told that the chunks cut out of one of them won't affect the setup when tightened down. I'll assume that with the metal half moon plates, one kit out floating around has 3 short ones and another kit has 2 longer ones instead of one kit having 5 total plates. I've been told 2 different stories on this matter. It does make sense that after you put the 3 plates, then you put the 2 longer ones over the seams in the 3 shorter ones for added rigidity. But who knows? |
02-22-2008, 01:51 PM
| | Re: Just bought 4 stroke Chinese frame mount kit I still haven't been able to locate anyone that sells the engine mount. |
02-22-2008, 01:57 PM
| | Re: Just bought 4 stroke Chinese frame mount kit I think i would look at making one. If you can that is... |
02-22-2008, 02:20 PM
Originally Posted by deacon I think i would look at making one. If you can that is... | I'd probably have to have it done and I don't want to complicate things that much when I know there are probably piles of the engine mounts out there somewhere, it's just a matter of finding a dealer that will actually sell one. Some of the better known dealers don't even answer emails, so it's easy to get stuck fast. |
02-22-2008, 02:52 PM
| | Re: Just bought 4 stroke Chinese frame mount kit I can imagine I have chased things before and it can be frustrating as heck,,,, Good luck | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:54 AM. | | | Sponsors
