| | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | 'jet' 80's info Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. does anyone have experience/knowledge with the "jet
80's"?
i've installed about 30 moters into customer's bikes but never a 'jet'.
01-05-2010, 12:15 AM
| | Motorized Bicycle Senior Member | | Join Date: Dec 2008 Location: jacksonville, florida
| | 'jet' 80's info does anyone have experience/knowledge with the "jet
80's"?
the price is right but what is their reputation?
i don't want to put a piece of crap in a customer's bike....
thanks for any input
stay dry
gubba |
01-05-2010, 07:48 AM
|  | Motorized Bicycle Member | | Join Date: Oct 2009 Location: Alabama
| | Re: 'jet' 80's info Here's P80j Jet Info - I only have experience with
the Grubee 80cc and the P80J Jet from Pirate cycles.
It maybe just me but the P80J seems to have a little
more power and bottom end torque. There's also a thread on
a complete tare down of the P80J on the forum.
Model : PK80J-SILVER
Engine type : Single cylinder, air-cooled, 2-stroke
Power * Rotary Speed Rated Power : 2.0Kw / 5000r / min (3HP/5000r/min)
Max Power : 3.5Kw / 6000r / min (5-6HP/6000r/min)
Ignition Mode : CDI
Fuel type : Octane 89 and above
Lubrication Oil : 2 Stroke Synthetic Motorcycle Oil
Mixing Ration for Fuel and Oil : 16:1 for new sets (20:1 after running approx 500Km)
Spark Plug : Z4C 14MM
Fuel Consumption : 2.5L / 100Km
Clutch Type : Friction Plate / Dry
Romans 10: 9-13
01-05-2010, 10:21 AM
| | Banned | | Join Date: Aug 2009 Location: pa
| | Re: 'jet' 80's info I did the PK80-J Teardown and Review.
Search it lots of good info.
I really really like the PK.
Very Powerfull
And Justin at Pirate Cycles is awsem when it comes to customer service. |
01-05-2010, 05:26 PM
|  | Motorized Bicycle Elite Member | | Join Date: Dec 2009 Location: Maine
| | Re: 'jet' 80's info Gubba,
"Jet" as in Silver/Black Jet stealth '80'?? |
01-05-2010, 06:06 PM
| | Re: 'jet' 80's info Yep PK80-J i believe |
01-05-2010, 09:05 PM
| | Re: 'jet' 80's info mac.....
i am interested the silver, but what difference would that make???
stay dey
gubaba |
01-05-2010, 09:48 PM
| | Re: 'jet' 80's info Well in my case, color would be a HUGE difference! (I bit my lip while writing that), For X-mas. I did 2 builds using new Schwinn Riverside's(7speed). I ordered 2 PK80 Stealth slant head kits. and the usual front mounts (SBP) etc,, well after the usual NGK plugs/tuning etc. The black is a Lame dog, un-tune-able, @#^%$#@$^^. The Silver is a dream machine. I plan on getting with PK tomorrow about warr. No power to.
The quality was good as far as being clean and clutch adjusted, rings all on ring pin guides, nothing missing.
I took the Silver for a ride today, I was taking advantage of the cooperating weather of 20deg F. :-). I finally tweeked the carb enough for it to clean out upstairs. Good pull and Huge Q too.
If you need any measurements or anything, let me know. The only thing that is different about the kits is the paint color.
Mac |
01-06-2010, 09:48 AM
| | Re: 'jet' 80's info I have both the black and the silver PK and they have both run the same for me.
If your black one isn't running good there must be somethin goin on.
What exactlly is it doing. I can prolly help you get it fixed up and runnin good. |
01-06-2010, 09:49 AM
| | Re: 'jet' 80's info If you check out my porting thread i have drawings of the port timing.
Cylinder / Piston / Con rod |
01-07-2010, 07:48 AM
|  | Your East Coast Gasbike Connection | | Join Date: Apr 2009 Location: Wista ma
| | Re: 'jet' 80's info Quote:
Originally Posted by Mac Well in my case, color would be a HUGE difference! (I bit my lip while writing that), For X-mas. I did 2 builds using new Schwinn Riverside's(7speed). I ordered 2 PK80 Stealth slant head kits. and the usual front mounts (SBP) etc,, well after the usual NGK plugs/tuning etc. The black is a Lame dog, un-tune-able, @#^%$#@$^^. The Silver is a dream machine. I plan on getting with PK tomorrow about warr. No power to.
Mac | Mac,
Did you get your black PK here from Pirate Cycles.. If so let me know, i'll swap it out for you..
No worries..
Justin
Pirate Cycles
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
