| Sponsors
| | | | | Gas Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here! | I cant pedal freely? Even with the cluch lever in. Discussion at Motorized Bicycle Engine Kit Forum in the Gas Bicycle Engine Kits forum. Originally Posted by misteright1_99
My kit had a frayed clutch cable right out of the box. I replaced the cable ...  | |
10-15-2008, 09:05 PM
| | Motorized Bicycle Apprentice | | Join Date: Oct 2008 Location: Melborne
| | Re: I cant pedal freely? Even with the cluch lever in. Quote:
Originally Posted by misteright1_99 My kit had a frayed clutch cable right out of the box. I replaced the cable with one from Wallyworld and also replaced the cheap russian style lever with a brake lever that matched all the rest of the levers on my bike. Unhook the cable from the clutch arm and make sure it moves freely inside the outer jacket. | PERFECT! works much better! I shorten the cable and cable tyied it straight from the handle bars, Half way down on the down tube untill it hits the black box then straight across to under the carb to the arm. Before the cable was 1+ meter long!
Thank you |
10-15-2008, 09:17 PM
|  | Senior Motorized Bicycle Builder | | Join Date: Aug 2008 Location: Houston
| | Re: I cant pedal freely? Even with the cluch lever in. I am so glad you got it fixed. Yes there is a ball under the plunger, I took it back apart on mine and it was still there and it did not fall out when the plunger fell,I know I would never find it if it did, |
10-15-2008, 09:57 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
Originally Posted by saolom PERFECT! works much better! I shorten the cable and cable tyied it straight from the handle bars, Half way down on the down tube untill it hits the black box then straight across to under the carb to the arm. Before the cable was 1+ meter long!
Thank you | In the future if you want to make it even easier, you can take the arm off, and rotate it inward a few splines for a more direct pull, as well as lengthen the arm with some tubing. Here is a picture of what I did....Its not a very good pic, so if you have any questions please ask.....
10-15-2008, 10:40 PM
Originally Posted by misteright1_99 In the future if you want to make it even easier, you can take the arm off, and rotate it inward a few splines for a more direct pull, as well as lengthen the arm with some tubing. Here is a picture of what I did....Its not a very good pic, so if you have any questions please ask..... | Good idea! should be doing that soon. Any other tips or advice you can give like to common problems with my china kit.
Thanx ma8 |
10-15-2008, 11:06 PM
| | Re: I cant pedal freely? Even with the cluch lever in. Another idea if you havent already would be to pull the clutch rod and ball and inject some grease there, and unscrew the clutch cable anchor under the carby and inject some grease there. I used a grease gun with a grease needle to get the grease in the clutch anchor hole. Makes quite a difference. There are sooooooo many improvements you can do, just have to search thru the posts to find the ones that will make a difference for YOU........
Read ALL Normans threads.........
10-16-2008, 07:58 AM
Originally Posted by saolom Good idea! should be doing that soon. Any other tips or advice you can give like to common problems with my china kit.
Thanx ma8 | Bicycle Motor Preperation And Care
10-16-2008, 08:00 AM
| | Re: I cant pedal freely? Even with the cluch lever in. P.S., If you adjusted the flower nut, and it works O.K. leave it alone....read my signature.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 07:26 AM. | | |
