| Sponsors
| Our Forums | | | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | how to shorten chain Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. Hi,
I need to remove about 7-8 links from my chain, it has a master link. What kind of tools ...  | |
10-07-2008, 02:17 AM
| | Motorized Bicycle Newbie | | Join Date: Oct 2008
| | how to shorten chain Hi,
I need to remove about 7-8 links from my chain, it has a master link. What kind of tools do i need. I dont have a dremel or a good drill or a grinder. |
10-07-2008, 07:22 AM
| | Motorized Bicycle Elite Member | | Join Date: Sep 2008 Location: Ontario Canada
| | Re: how to shorten chain You should get a chain breaker tool.It will come in handy later too. you are asking what kind of tools you need,well, either a dremel or a drill or a grinder will work too,perhaps you can borrow one of these from someone, or as a last resort go to a bike shop and ask them to remove the links for you. Should be no more than 5-10 bucks.
If you are careful you can also punch out the pin with a nail or something. |
10-07-2008, 07:46 AM
| | Re: how to shorten chain The pins are pretty hard to punch out, nearly impossible to punch back in. Get a good breaker or find somebody with tools and an interest in motorized bicycles.
10-07-2008, 04:48 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Cropwell Alabama
| | Re: how to shorten chain You can get a chain breaker tool in the bike section at Wal-Mart for under 5 bucks.  |
10-13-2008, 01:36 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Palm Springs CA.
| | Re: how to shorten chain i just whent thru this problem.
i whent and bought the 4.95 bell chain braker at wall mart.
it fits a 415 chain but when you go and brake it, the thereds stript.
so bought a new one and the chain post broke!!! BS
so i went to a local bike shop(try a bike) and they broke it with know problem with a Park tool chain braker. so i whent and orderd own from SBP
( Welcome to Sick Bike Parts) and its perfect!!!
save your money |
10-13-2008, 06:45 PM
| | Re: how to shorten chain Yeah, those Bell jobbies from wmart are junk.
10-13-2008, 07:03 PM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Beverly, MA USA
| | Re: how to shorten chain don't buy the aventura brand at dick's sporting goods either, I broke one in the middle of my build. POS. wish I could find my old chain breaker... |
10-13-2008, 07:07 PM
|  | minor bike philosopher | | Join Date: Jan 2008 Location: north carolina
| | Re: how to shorten chain Get a cheap file and a punch, with a master link you just have to knock out the links you don't want. I usually try to put them back together and not use the master link but if you are in a jam just file down the pin and knock it out. Be careful though to get the right length. |
03-23-2009, 10:22 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: Top of NY
| | Re: how to shorten chain I cut the link in the chain with a jigsaw or you can use a hacksaw,
cut one link,count from there how many to remove,then cut again
break off the cut link pieces with pliers,pieces come right off,and pins fall right out,then slide a master link right in its place,pins go in easy- joining the 2 sides of chain back together,its easy this way |
03-24-2009, 02:28 AM
|  | Motorized Bicycle Senior Member | | Join Date: Feb 2009 Location: Honolulu, HI
| | Re: how to shorten chain Dremel is cheap, and SO handy. That is what I used! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:57 AM. | | |
