Horn electrical
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. Hello out there, I have a CH80 2 stroke with a blue, black and white whire coming out of the ...
Old 05-27-2009, 08:30 PM
Default Horn electrical
Hello out there, I have a CH80 2 stroke with a blue, black and white whire coming out of the engine...Anyway my question is simple for some but I'm affraid to connect a wire to the wrong wire and fry something....I bought an old motorcycle or scooter 6V horn off ebay and tested it on a 6v flashlight battery and it works great...Now I know one wire has to go to the white wire but do I go to the blue or black for the other wire...I'm not an electrical guy so any help would be great....Thanks
Old 05-27-2009, 08:39 PM
Cabinfever1977's Avatar
Default Re: Horn electrical
one to white(power) and one to black(ground),the blue is a high power wire(u dont want to use that or you will blow something.
Old 05-27-2009, 08:50 PM
horn will draw too much
Old 05-27-2009, 11:13 PM
Thanks for the help...I was worried I would pop something so I'm glad I asked..Thanks again !
Old 05-27-2009, 11:14 PM
Yeah I thought it might but only plan on usuing it when I have to...Or are you saying that its a constant draw being used or not ?
Old 05-27-2009, 11:24 PM
if the horn uses more than .5A, then it'll ground out the engine, and it'll shut off.. most horns operate at 5A or so
Old 05-28-2009, 04:07 PM
so if you honk your horn your engine will shutoff.
Old 05-28-2009, 06:02 PM
yeah its kinda looking that way...I'm gonna give it a try and if it shuts the engine down I'll have to figure out another way.....Im thinking about maybe figuring a way to run the horn through one of those small 6 volt dog collar batteries...but they are kind of expensive...I just dont want one of those larger flaslight 6 volts clamped to the side of the bike...Michigan law says a horn audible to at least 200 feet and I live in a small town so they'll hear me comming whenever I ride....
  #9 (permalink)
Old 05-28-2009, 06:19 PM
2door's Avatar
Your horn is probably DC (direct current) and the white wire is AC (alternating current) and it probably will draw enough to kill your engine's ignition anyway. There are all kinds of small batteries less expensive than the dog collar type that can be easily mounted on a bike. Most of them are refered to as SLA (sealed lead acid) batteries and can be purchased at hardware stores, industrial suppliers, even Wally World (Walmart) carries them for battery powered riding toys. You'll need a pushbutton (momentary switch) wired in series (in line) with one of the two wires from the battery to the horn. Hope this helps.
Over Youth and Skill
  #10 (permalink)
Old 05-28-2009, 06:20 PM
cheap hand held marine air horn will pass that requirement
