Originally Posted by blacktop_sailor I'm kind of in the same boat as Ritchie.
I was originally looking at one of the Skyhawk II kits, since I'd prefer a 4-stroke, and I'd also prefer an in-frame install.
But none of the rear sprocket's look like they'll fit my bike with the drum brake on the rear.
I just had that problem with my PK-80 kit
I measured the brake hub with a cheap 4"
brass caliper, about $3-$5 at a hardware store
or on fleabay.
Anyway, it measured just under 1 7/8",
so I traced it out on the sprocket and trimmed
it out with a die grinder and a 1/4" rotary file.
I would suggest as a cheaper alternative (since most folks dont
have a $200 die grinder). Get a hole saw of proper size and the
necessary arbor. screw the sprocket onto a piece of wood, find the center
by using the bolt holes. start the pilot bit into the wood and be sure that you
get a straight bite when cutting into the metal.
It should go pretty quick, you can oil the hole saw blade and it will cut better
without burning the metal. If you decide to change sprockets, you already have the tooling to complete the job.
-J.R.-
