Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Help! My head is spinning from the plethora of available kits!
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Originally Posted by blacktop_sailor I'm kind of in the same boat as Ritchie. I was originally looking at one ...
  #11 (permalink)
Old 05-21-2008, 03:01 PM
Boilerman420's Avatar
Motorized Bicycle Apprentice
Default Re: Help! My head is spinning from the plethora of available kits!
I was originally looking at one of the Skyhawk II kits, since I'd prefer a 4-stroke, and I'd also prefer an in-frame install.
But none of the rear sprocket's look like they'll fit my bike with the drum brake on the rear.
I just had that problem with my PK-80 kit
I measured the brake hub with a cheap 4"
brass caliper, about $3-$5 at a hardware store
or on fleabay.
Anyway, it measured just under 1 7/8",
so I traced it out on the sprocket and trimmed
it out with a die grinder and a 1/4" rotary file.
I would suggest as a cheaper alternative (since most folks dont
have a $200 die grinder). Get a hole saw of proper size and the
necessary arbor. screw the sprocket onto a piece of wood, find the center
by using the bolt holes. start the pilot bit into the wood and be sure that you
get a straight bite when cutting into the metal.
It should go pretty quick, you can oil the hole saw blade and it will cut better
without burning the metal. If you decide to change sprockets, you already have the tooling to complete the job.
-J.R.-
  #12 (permalink)
Old 05-21-2008, 03:07 PM
Bikeguy Joe's Avatar
Genius Visionary
A little work with a grinder or really go at it with a dremel and you can make the sprocket center hole large enought to clear your drum...it may not end up being the prettiest, but it will work.
  #13 (permalink)
Old 05-21-2008, 03:15 PM
blacktop_sailor's Avatar
So you think it would still attach to the spokes with the rag coupler, even with the larger hole being ground in it?
If so, then that would make an easy solution, even if it isn't the prettiest.
Universal Truth: Follow the "Fat Guys", we know where to find all the best food
  #14 (permalink)
Old 05-21-2008, 03:18 PM
Genius Visionary
Yeah, should work fine.
  #15 (permalink)
Old 05-21-2008, 06:38 PM
deacon's Avatar
I enlarged my hole with a 3/8 drill and a metal rasp from the home depot. Like joe said it weren't dressed for the prom but it worked okay.
Advertisers
