Gas Tank leaking out through Carburetor
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. So since I am a "Newbie" I get to make all sorts of posts about my troubles. Occasionally ...
Old 05-08-2009, 01:19 PM
Default Gas Tank leaking out through Carburetor
So since I am a "Newbie" I get to make all sorts of posts about my troubles. Occasionally my gas tank will completely drain out through my carburetor. It was quit a surprise the first time I came out and all the gas and oil had spilled all over my back porch. At first I thought it happened when the engine was choked out and then never restarted but I have done that in a long time. And I kinda would like it to stop. . . I've got in the habit of turning the gas valve off before I walk away so if it does leak its not very much of my tank.
So the question what do I do!?!
Old 05-08-2009, 03:15 PM
ebmvegan's Avatar
Default Re: Gas Tank leaking out through Carburetor
Your float could also be getting stuck. Smooth out the bowl with fine sand paper and make sure that the carb is sitting level.
There is no moment like the now moment.
Old 05-08-2009, 06:47 PM
2door's Avatar
My first question would be have you checked your fuel petcock? Some of them do not shut the fuel off when the lever is 90 degrees to the fuel line. Turn the petcock off then disconnect the fuel line from the carb. Is the fuel still running out of the tank? If so move the lever until it stops then mark and remember where the lever needs to be to actually stop the flow of fuel. If you're unable to stop the flow with the petcock then replace it. Let us know what you find and DO NOT run your engine on pure carburetor cleaner. That's a good way to score a piston and cylinder walls.
Over Youth and Skill
Old 05-08-2009, 10:31 PM
Cabinfever1977's Avatar
turn off your petcock when youre not using the bike.
if the petcock dont work nomore,replace it with a diffrent one.
Old 05-09-2009, 05:14 AM
lordoflightaz's Avatar
With the petcock closed, take the gas line off the petcock. Check to make sure it is not still letting some fuel through. Move the lever on the petcock until it really is shut off. Use a "sharpie" or scribe a line in the metal to mark where "off" really is. When you turn off the fuel put it on that line. This has pretty much solved my leaking issues with the stock petcock.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike.
If trailer parks didn't exist would tornadoes exist?
Old 05-09-2009, 10:38 AM
Norman's Avatar
LORD VADER Moderator
leaking out all the fuel when not in use is signs of a float needle sticking or not set right. You are using a fuel filter? wallyworld sells a fuel filter in the lawn and garden area it clear with a paper element about $5.00 or less. check out my carb tear down should get you on track for the carb if not let me know I might need to do some pictures and text on setting the float.
you can look here for info on the carb
Motorized Bicycle Carburetor install and rebuild
norms-iron-works.tripod.com
Old 05-09-2009, 10:45 AM
Okay so if I arrange what everyone has said . . . If the petcock is off and I'm still leaking everything I have 2 problems the petcock "off" is not completely off and the carb float is sticking. If the bike doesn't leak when the petcock is off its just a sticky float.
Since I think the "off" works . . . I need to make sure the carb is sitting level, sand out the inside of the bowl so nothing on the sides could affect it and make sure the line is being filtered so crap doesn't get stuck in there and cause the float to get stuck in unwanted positions. . . Is that right?
Old 05-09-2009, 02:32 PM
Norman's Avatar
I think either you have some crud under the floats needle allowing it to stick open or the float is not adjusted quite right have not seen the float stick on the float bowl yet. It usually has a good finish in the inside I'd hold off on sanding anything inside the float bowl, unless you see a big booger in it.
most times it is crud sticking in the floats needle just needs a cleaning do not poke the opening with anything or sand the needle on the float, compressed air or carb cleaner works best and with the carb upside down and the float bowl off you can see if the float is setting level which it should be. check out my post on the carb too.
there is a link on #6 - 2 posts up.
Norman
  #9 (permalink)
Old 05-09-2009, 10:38 PM
yep you got it right
  #10 (permalink)
Old 05-12-2009, 12:33 AM
Emerica's Avatar
Check most of the philips heads on the carb as well as tighten/seal up the intake nozzle.(carefully)
Both our kits have drain plugs , and a couple of the screws have shotty washers.
They tend to leak if not tight, and can come loose enough to leak easily.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f4/gas-tank-leaking-out-through-carburetor-7986.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 05-08-2009 04:29 PM
