Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
gas leak
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. this seems to be a problem some people have with the carbs that come with the 2 stroke kits. if ...
Old 12-27-2007, 09:19 AM
CRUISER's Avatar
ADMINISTRATOR
Default gas leak
this seems to be a problem some people have with the carbs that come with the 2 stroke kits. if this happens take the float bowl off and check that the fork that lays on the float inside the bowl, is sitting up far enough. just bend the fork up a little and now it should stop the leak. the fork when pushed up, also push in a little pin into the bottom of the fuel inlet and stops it from over flowing. when it over flows it finds a place to come out and that usually is the primer button area
Old 12-28-2007, 08:48 PM
ChrisHill's Avatar
Manufacturer/Dealer
Default
Not to add in to the confusion here but, what you want to do is spread the opening. The area that makes contact with your float pivots and pushes against the needle valve...if you spread this area larger it will cause the valve to close before the float bowl gets to full...thus stopping leakage around the primer. If you open it up too much though, you could prevent enough fuel from getting into the carb...balance things out, and don't over do it.
I have a few carbs laying around that need to be cleaned. If i can find some time this weekend I'll see about trying to get some decent pictures to post up.
After all, a pictures is worth a thousand words...or at least it sure helps to explain things better, lol.
Yes, I really do ride what I sell...everyday.
www.chrishill.myknet.org
Home of the CH80 Bicycle Engine Kit...for those that want quality.
Old 01-26-2008, 08:04 PM
Motorized Bicycle Builder
Default Re: gas leak
Mine leaked because the gasline was too big for the carb nipple, and a clamp was almost impossible to get in there ---just not enough room I finnaly found a smaller diameter gas line that would fit really tight on the tank but perfect on the carb. It was not see thru which I dont like but it does not leak,which means I can keep it in the basement .
My wife can smell a gas leak 2 blocks away. If momma aint happy nobodys happy
Ted
Old 01-26-2008, 08:15 PM
deacon's Avatar
all women can smell gas. they should use them for oil well locations.
visit my blog if you dare http://chinesekitmotorbike.blogspot.com/
Full novel on the blog in serial form.
CRUISER's Avatar
ADMINISTRATOR
you got that right teddy. i think mine can smell it 3 blocks away though
Old 01-27-2008, 07:13 PM
Norman's Avatar
LORD VADER Moderator
Didn't I post the carb how to one here with pictures and text form start of finish?! If you can find it your questions should be answered.
Norman
The below is wrong in ( )
The search does not seem to be working for me. (I found it go to the home page type in search) the first is wrong don't go to home as I could not get it to work from home go to the 2 stroke page type in the search (carb how to) and hit go and TADA all you ever wanted to be lied to about the nasty little carb let me check again as I left something out. or you could have scrolled down.Dang I quit the thing is now at the top someone having fun .
Old 02-18-2008, 08:14 PM
Autocycler's Avatar
Ted[/quote]
So true. My wife doesn't share my appreciation of fuel vapor potpourri wafting through the house 24-7....guess it's an acquired taste
Then again, she doesn't exactly appreciate my "motorbikes as art" decor in the living room either.
Old 02-18-2008, 09:18 PM
deacon's Avatar
You got a bike into the house at all...... my hero
  #9 (permalink)
Old 02-21-2008, 11:16 PM
MotorbikeMike's Avatar
Dealer
Hi well mine doesn't like my Model 09 in the living room either, I had to put it out in the trailer this afternoon, and I was just thinking how nice it looked, right here where I can see it.
Mike
www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
  #10 (permalink)
Old 02-22-2008, 10:50 AM
Autocycler's Avatar
Yep, and mine (the phantom) starts so easily in the morning if he's been in the warm house all night...guess he likes being inside. MY wife is getting used to the idea of sharing the house with our motorized children.
Steve
Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
