| | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | Engine won't start Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. I just finished assembling my first ever bike engine kit (from BoyGoFast on EBay; Kit Model H2-80). I am ...  |
06-17-2009, 01:56 PM
| | Motorized Bicycle Newbie | | Join Date: Jun 2009 Location: Vermont
| | Engine won't start I just finished assembling my first ever bike engine kit (from BoyGoFast on EBay; Kit Model H2-80). I am certain that I have assembled this kit correctly, however, the engine will not start. Won't even "pop" or sputter! I know fuel is getting into the cylinder because I pulled the spark plug and could smell the fuel (16:1 ratio right now) inside the cylinder and on the plug.
Engine wires to CDI wires are connected "Blue to Blue" and "Black to Black". I haven't connected the Kill Switch yet as I wanted to get the engine going and adjusted first.
Any ideas of what is wrong? |
06-17-2009, 02:40 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2009 Location: michigan
| | Re: Engine won't start Are you getting spark to the plug? and check your plug gap too. AN easy way to check if you have spark is to remove the spark plug put the cap back on then ground the end of the plug to the motor and spin your tire to crank over the motor. |
06-17-2009, 04:17 PM
| | Re: Engine won't start reg454-
NO SPARK, but I did get a shock (twice actually) so I'm guessing that rules out the CDI and/or engine electrics as the culprit!
With spark plugs as cheap as they are, I probably should just a new Plug. Can you suggest a better made replacement plug (like Champion or whatever)? The manual lists a few different plugs for this engine (I'm guessing these are all Chinese products).....Z4C or NGK BP-6L or NGK B-6L or NGK R7-HS. Thanks! |
06-17-2009, 04:20 PM
|  | Motorized Bicycle Senior Member | | Join Date: May 2009 Location: East Wenatchee, Wa
| | Re: Engine won't start I went thru this same problem and it turned out my clutch wasnt completely engaging. It was only turning the motor over completely once in a while and thats not enough to start it. Good luck!  |
06-17-2009, 04:55 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: Oregon
| | Re: Engine won't start Quote:
With spark plugs as cheap as they are, I probably should just a new Plug. Can you suggest a better made replacement plug (like Champion or whatever)? The manual lists a few different plugs for this engine (I'm guessing these are all Chinese products).....Z4C or NGK BP-6L or NGK B-6L or NGK R7-HS. Thanks! | You may get shocked but if that plug won't spark something is wrong. I spent almost a year working on an 80's Motobecane, same issue I could get shocked to S*** but that plug would not fire. It was either a short somewhere or the cdi wasn't transforming the power right, I could't tell you which because I replaced all the wiring and the CDI then it worked. But like I said just because you get shocked doesn't mean it's gonna spark. Have you done anything with the white wire? at least double check and make sure it's not shorting somewhere. |
06-17-2009, 05:36 PM
| | Re: Engine won't start Try replacing the wire that goes from your cdi to the spark plug first then retry to start your bike also make sure the proper spark plug gap is their. Remove the cover for the magneto and make sure all the bolts are tight, especially the black wire. The plug wire that come with these are cheap i took mine apart after i replaced it and their were only 4 wires in it use a thick wire it should improve your spark. |
06-17-2009, 06:19 PM
| | Re: Engine won't start OK, I opened up the magneto and all the bolts are tight, and the magnet turns when the bike is pushed. But the White wire is not attached to anything. I don't know if that matters or not. I would have to order the spark plug wire then. |
06-17-2009, 06:38 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: upstate NY
| | Re: Engine won't start you dont need to replace the stock plug until you figure out what is wrong with the engine.
mark clean your airfilter,gasfilter,muffler and change out your sparkplug. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:14 AM. | | | Sponsors
