Re: Engine won't idle You are clogged somewhere It should make a darn messy puddle quickly! It should flow faster than that . The petcocks clog up very easily , when trash gets to them. Are you sure the screen in the tank is not clogged? They fall apart very easily too! That will clog the petcock. If your kit did not come with one do get a in line filter. I had a fit with my set up . I did away with the tank filter . Then I used a swamp cooler water cut off valve it has a bigger orifice flow channel to it. But thats just me.
One can do anything you set there mind to.... Do a good thing...
