Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Engine Whinning
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. You could drill and tap the area where the main shaft goes through and put in a grease ziert shouldn'...
  #31 (permalink)
Old 06-15-2008, 08:06 PM
Norman's Avatar
LORD VADER Moderator
Default Re: Engine Whinning
You could drill and tap the area where the main shaft goes through and put in a grease ziert shouldn't be a problem but if you take the clutch cable holder out and shoot a little grease in there it should be good to go for quite a while.
Don't get carried away with greasing it. I only greased that area when I first mount the engine new and can watch both sides so I don't over do it. It will not get greased again unless I take it apart for some reason or I just want to play with it for some sick reason and take it apart and clean all the grease out of the shaft and bearings.
norms-iron-works.tripod.com
Advertisers
