Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Engine runs with half choke only
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Let us know how you make out David......
  #11 (permalink)
Old 06-06-2008, 09:13 PM
Default Re: Engine runs with half choke only
  #12 (permalink)
Old 06-08-2008, 10:21 AM
Pablo was right. When I put the engine together I noticed that the needle in the carb was kind of fat after pablo mentioned it, so I switched the pin out with one I know runs good. Runs perfect. Sanded the pin that was in it for awhile, put it back in runs much better now only 1/4 choke. Intentionally did not sand down too much because I can not go back. Will sand some more today, and see what happends. Thanks for all of the help, Especially Pablo, and ThatsDax. Pablo because he called it and ThatsDax for scareing me into fixing it right, and for haveing a good pin in the engine that I bought from him to begin with. The good pin cam out of the Dax engine. It was a BoyGoFast engine that had the pin problem. Not trying to say it is a crummy engine just something to look out for with the Boy Go Fast engine. It is a slant spark 50cc.
  #13 (permalink)
Old 06-08-2008, 10:36 AM
Pablo's Avatar
I learned that one the hard way - I went through weeks of battling the same problem, so I bought a new carb ($22) and it ran like a champ! I sent the old carb to Norman. He's the one to thank - he said "Your needle has no taper!" (actually it had some, but it was too fat)
Anyhow I think there obviously is some flaw in China......
Cool thing is I now have two carbs to experiment with.
  #14 (permalink)
Old 06-08-2008, 02:44 PM
Bikeguy Joe's Avatar
Genius Visionary
[quote=Pablo;13638]
QUOTE]
Yeah, it's called "No quality control".
  #15 (permalink)
Old 06-08-2008, 06:06 PM
MarkTur's Avatar
Originally Posted by misteright1_99 View Post
I saw that post on drilling the .040 hole in the carb and did it and mannnnn it made sooo much difference. I too have the carb/intake oringed, no rtv. I guess it is possible that if there is way too much oil to fuel then it might need less air to run, but I would still look for an air leak.
Please point me to the post...and how hard was it to do, and what's the benefit?
Have you cleaned up your ports and gaskets yet? I think I'm going to do a bunch of work on the carb this week after what I'm reading...
Thanks,
Mark
Cya!
Mark Turkel
http://www.AreWeOnline.com
http://www.PalmBeachSoftware.com
HT 70cc ...lots of extras
Kulana Moon Dog Aka BLUE DOG
Like someone else said "Sticking it to the Man!"
  #16 (permalink)
Old 06-08-2008, 07:43 PM
Thanks,
Mark
I have cleaned all my ports and matched them to the intake and exhaust, installed all new gaskets. Made for a much smoother running engine. I am now in the process of rejetting. I will have to look for the post drilling the carb. It is simple to do, just need to go to a hobby shop and fing the right sized drill bit, and collett for dremel. It does make a difference with the idle since these carbs have no idle circuit..
  #17 (permalink)
Old 06-08-2008, 09:21 PM
Porting, Make sure you stick some rag or something in the exaust pipe when grinding on it. So you do not get metal flakes back in your engine.
Advertisers
