K so I'm starting to loose my mind...
I have a "80cc" 'Black Stallion' (NGK plug & nicely colored, 32/1 Amsoil*, no mods) kit on me bike and it's been a bit of a chore to get it running right. Four stroking for the longest time, now it's all broke in nice and running like a champ - mostly.
You may remember my "fuel starvation/hose clamp" post, maybe not - but the problem is the bike runs
great until just about top speed (30mph) and then it just shuts down. Like off! Back down the throttle, it'll idle even - but unless you give it a few moments to recover from what ever is ailing it all that happens with a throttle twist is sputtering popping BS.
Give it a few (like 30 seconds or so) and she's fine - unless you try to get to top speed again
If I maintain speed at less than WOT, everything is fine. Give it to her, everything's fine. Try and hold top speed/high rpm & WOT = same as if I hit the kill switch.
The symptoms seem
exactly the same as fuel starvation - but I've seriously been through the system. I've tried w/o the gas cap on in case it wasn't venting = no joy. I've pulled the line to check flow = it's fine, even down to the last drop. I went ahead and replaced the petcock, line, & filter = it's no better. I've even run about w/o my air filter in as it isn't stock and I wondered if it was too restrictive = nope, still not it... Floats? no - that'd be too easy ofc. Best yet - this is not an intermittent problem, it does this
every time, but it has to be wide open throttle
and at top speed/high rpm.
So at this point I'm out of ideas. I've got a Grubee comin in from the boys o'er at Spooky - I'm gonna swipe the carb off of it as the Grubee kits do have slightly nicer ones than mine, but I really don't think that's gonna help, I'm really starting to wonder if it's a fuel or air prob at all...
Could it be the CDI? I really can't figure this 'un out - it's driving me insane! The bike runs so well
other than this little problem... grrr
*32/1 Amsoil is with their 50/1 injector flavor btw, great stuff
