| Sponsors
| Our Forums | | | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | E-85 gas??? Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. i pay 75cents for a liter which is what i put in my tank and im getting 180-200mpg.
how much ...  | |
07-03-2009, 01:08 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: Top of NY
| | Re: E-85 gas??? i pay 75cents for a liter which is what i put in my tank and im getting 180-200mpg.
how much cheaper does one need to get?
It would cost me around $50 in gas plus $5 in oil to go from NY to California.
07-03-2009, 04:26 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: usa
| | Re: E-85 gas??? figuring todays cost of gas, is 1.00 more than E-85 in some parts of the country.. that figuring, you would pay about 30 cents ( I'm not doing any math, but I know it's close ) and go 130 miles.. I know we don't have E-85 readily available in Ny as, last I heard there were 2 stations in Albany and 1 in NYC and that was it |
07-04-2009, 03:26 AM
| | Banned | | Join Date: Apr 2009 Location: PA
| | Re: E-85 gas??? I plan to try it at some point, just figured there were 0 posts about it on here and if it's do-able.. could be worth it... closest E-95 station from me is 21 miles... $1.89/gallon
P.S. that noob-tube video is pretty darn bad quality...
07-04-2009, 08:25 PM
| | Re: E-85 gas??? I stand by my signature...
07-04-2009, 10:29 PM
|  | Motorized Bicycle Member | | Join Date: Jun 2009 Location: Lancaster, PA
| | Re: E-85 gas??? Someone mentioned something about the "removal" of octane. This is totally incorrect. E-85 has an octance rating of ~105. Its the best thing ever for a turbo powered car.
The thing people don't understand though is the higher the octane the less power! Unless you increase compression, advance timing, or increase your boost level your only gonna go slower and use more fuel. |
07-04-2009, 10:45 PM
| | Re: E-85 gas??? what the higher octane does, is keep the A/F mix from preigniting ( detonation ), and only ignite with the spark. ( higher heat/ compression needs it to maintain it's stabillity ).. it doesn't make it any weaker, but it also doesn't make it any stronger.. you will use more E-85 than gas because the thermal efficiency of alcohol is a little less than gas... main thing is, if your going to run E-85, you have to check the plug regularly and tune accordingly.. if you have 1 , use a pyrometer or non contact thermometer, and take EGT's, make sure they don't run too hot... E-85 could burn the engine up, if it's tuned incorrectly, but tuned correctly, just like anything, should run just fine.. I'm a hotrodder by nature, so taking the road less travled is what I do.. |
07-05-2009, 02:50 AM
| | Re: E-85 gas??? I agree higher octane is to slow the burn of the gas. Stops the pinging in a high compression motor. But high alcohol gas makes a hotter burn. Will also rust the inside of the tank so make sure your using a filter. Richer mix will make it work. Marvel Mystery Oil? Uh I don't think so, it's a mix of oil and kerosene from what I've read. I know that I broke my motor in with Valvoline 2 stoke for air cooled. After the first 3 gallons I switched to synthetic and went to 32:1 mix and my bike is faster and runs better. I pulled my jug to replace the base gasket and the bottom end is lubing really nicely. I have over 1000 miles on it now.
__________________ Put something FUN between your legs.. |
07-06-2009, 10:03 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: ny,ny
| | Re: E-85 gas??? Quote:
Originally Posted by Junster Marvel Mystery Oil? Uh I don't think so, it's a mix of oil and kerosene from what I've read. | Junster, I would like to know where you read that. MMO is actually pure naphtha with small amount of wintergreen oil to mask the fact that it's naphtha which is about 1/3 price in the paint dept.. One quick wiff will tell you. It is used to clean out carbon and does a pretty good job.
As far as that video I've run with no oil at all for longer than that in a junk engine just to win a bet. Never did seize or blow up.
Ethanol has been studied extensively in aircraft engines and found, contrary to popular belief, to do no harm. They were saying it corroded cylinders, made Bing diaphragm brittle, etc., all baloney. What it does do is waste tax dollars because in fact it's considerably more expensive to produce than gas, now and in the near future. Lobbyists for big farm (corn) interests are the real the reason it's there.
Reason: spelling
07-07-2009, 12:04 AM
| | Re: E-85 gas??? Thanks for the heads up on the marvel mystery oil. Like I said alcohol can rust the inside of the tank. Alcohol collects water. That's why it's added to your gas tank if you have water in it. It will absorb the water and allow the injectors if you have them to pass it thru. The problem with corn for alcohol production is the low sugar content. About a 5% return. Products like sugar beets however go much higher. Every car sold since 1986 in Brazil can run on pure alcohol. Alcohol there is about half the cost of gas. Alcohol burning engines also do not acidify the oil in 4 stroke motors. Gasoline blowby acidify's motor oil breaking down the viscosity. Thats why it's important to have a good thermostat. To get your oil up to a high enough temp to boil the acid off and send it out the tailpipe via the pcv valve. Running a 2 cycle engine without oil mixed in the gas will kill and seize the motor if you run it long enough. A well broken in motor will run for a while but it is wearing it out very quickly. If MMO is naptha then using cigarette lighter fluid as mix is going to be a poor form of lubrication.
07-08-2009, 09:23 AM
Originally Posted by Junster Thanks for the heads up on the marvel mystery oil. Like I said alcohol can rust the inside of the tank. Alcohol collects water. That's why it's added to your gas tank if you have water in it. It will absorb the water and allow the injectors if you have them to pass it thru. The problem with corn for alcohol production is the low sugar content. About a 5% return. Products like sugar beets however go much higher. Every car sold since 1986 in Brazil can run on pure alcohol. Alcohol there is about half the cost of gas. Alcohol burning engines also do not acidify the oil in 4 stroke motors. Gasoline blowby acidify's motor oil breaking down the viscosity. Thats why it's important to have a good thermostat. To get your oil up to a high enough temp to boil the acid off and send it out the tailpipe via the pcv valve. Running a 2 cycle engine without oil mixed in the gas will kill and seize the motor if you run it long enough. A well broken in motor will run for a while but it is wearing it out very quickly. If MMO is naptha then using cigarette lighter fluid as mix is going to be a poor form of lubrication. | All true. I wonder how long the engine in that video will actually last. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:54 AM. | | |
